VideoHelp.com Forum
    I admit it, I am new to the DVD realm. After lurking and searching I think I found my answer. The question was: How do I take the files on a DVD I made from VHS using DVDirect (Sony), into an editing software so I could delete scenes, add transitions etc, then make a new DVD.
    I read about VOB2MPG. Downloaded and installed it along with .netframe.
    Everything went OK w/o error. I ran VOB2MPG, told it where the video_ts file was and told it to put the mpg in desktop/test. When it finished, there was nothing in desktop/test. Where is my file? I searched my drives for *.mpg without finding a video_ts anything. Also, doesn't this "ripping?" software need the second folder called video_rm?
    Thanks for the help.
  2. Member Krispy Kritter's Avatar
    Does the desktop/test folder already exist or are you letting the program try to create it?
    I've never used it, but it should only need to know the video_ts folder like it asked you. As for the output file, it should be listed as the name you told it to save it as.
    Google is your Friend
  1. Can VOB2MPG Pro combine VOBs from two disc into one mpg file?
    By buzzworm in forum Newbie / General discussions
    Last Post: 17th Mar 2012, 16:22
  2. Replies: 10
    Last Post: 17th Jan 2010, 08:50
  3. VOB2MPG (converted MPG file has no audio!)
    By sonicdeth in forum SVCD2DVD & VOB2MPG
    Last Post: 5th Jan 2010, 19:23
  4. No audio in preview or output MPG file in VOB2MPG 2.0
    By scruzphreak in forum SVCD2DVD & VOB2MPG
    Last Post: 16th Jul 2009, 12:20
  5. Replies: 2
    Last Post: 4th Jun 2009, 14:02
