I have just loaded ffmpegx onto a new G5. I am receiving the below text in the Progress window when attempting to convert using the MP4 H.264 preset. I have successfully used this conversion on a different MAC - however I cannot get past this - as it never appears to begin converting. Any ideas?
Encoding started on Sun Dec 11 19:15:40 EST 2005
MEncoder dev-CVS-051126-18:35-3.3 (C) 2000-2005 MPlayer Team
Mac OSX static build for ffmpegX
AltiVec found
CPU: PowerPC
success: format: 0 data: 0x0 - 0xf0022640
Encrypted VOB file! Read DOCS/HTML/en/dvd.html.
Thread: DV to MP4 H.264
Greetings,
this seems to be the evil
Looks like your vob is copyprotected. Do you try to encode directly
from a DVD? Try to rip the vob to harddisc fírst with a programm that
removes the encryption (Mac the ripper)
Michael
Thanks for the response. However I'm not ripping a DVD in this scenario. I am actually exporting the DV straight from iMovie. That is my source for ffmpegx. My attempt at convering it using the MP4 H.264 preset fails in this manner - every time. I am re-instsalling ffmegx and mplayer, mpeg2enc, and mencoder. Hopefully that may clear this up.
fyi - I ran the same conversion under 0.0.9t without any problems.
I just reinstalled ffmpegx and the associate binaries. I still receive the Encrypted VOB file! Read DOCS/HTML/en/dvd.html msg in the viewer when attempting to convert my iMovie DV to MP4 H.264.
Note that this is only happening when I choose the MP4 H.264 preset. Using the MP4 preset works fine.
Is there an archive where I can get previous versions?
nevermind
My exported DV had 2 minutes of a commercial video clip at the beginning. Once I cut that portion out, it appears to be converting fine. Sorry.
Lossless Conversion from AVI H.264 to MP4 H.264
By kenchen in forum Video ConversionReplies: 3Last Post: 22nd Oct 2010, 14:04 -
How to convert an h.264 MKV with softsubs to an h.264 MP4 with hardsubs.
By hawk16zz in forum User guidesReplies: 4Last Post: 27th Apr 2010, 11:41 -
h.264/MP4 w/AC3?
By climbs in forum DVD RippingReplies: 17Last Post: 2nd Nov 2009, 19:10 -
What is the best program to convert from H.264 mp4 to H.264 avi?
By Stealth3si in forum Video ConversionReplies: 6Last Post: 15th Sep 2007, 10:11 -
Converting .avi (Xvid) to .mp4 or .mkv (H.264 or x.264) w/ subs
By Tensai in forum Video ConversionReplies: 4Last Post: 18th Jul 2007, 09:25
