VideoHelp.com Forum
    Greetings,
    i have a file produced with the Alchemy TV card (Apple intermed + PCM audio) which i am unable to encode to h264.mp4
    Maybe you help me out
    http://www.michaeldicker.com/privat/ffmpegx/HSTEST.mov (1MB)
    <edited because of lack of info>
    First, it does not recognize the file well. Wrong size, aspect and length.
    Is that the reason for failings that it does not recog Apple intermed codec?
    Encoding started on Sat Dec 10 20:49:13 CET 2005
    MEncoder dev-CVS-051126-18:35-3.3 (C) 2000-2005 MPlayer Team
    Mac OSX static build for ffmpegX
    AltiVec found
    CPU: PowerPC
    Cannot find codec matching selected -vo and video format 0x646F6369.
    success: format: 0 data: 0x0 - 0xe600c
    ISO: File Type Major Brand: Original QuickTime
    Quicktime/MOV file format detected.
    MOV track #0: 3 chunks, 10 samples
    Image size: 752 x 572 (24 bpp)
    Display size: 752 x 572
    Fourcc: doci Codec: 'Apple Intermediate Codec'
    MOV track #1: 3 chunks, 0 samples
    Audio bits: 16 chans: 2 rate: 48000
    Fourcc: sowt
    VIDEO: [icod] 752x572 24bpp 25.000 fps 0.0 kbps ( 0.0 kbyte/s)
    [V] filefmt:7 fourcc:0x646F6369 size:752x572 fps:25.00 ftime:=0.0400
    Opening video filter: [expand osd=1]
    Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
    Opening video filter: [scale w=752 h=568]
    Opening video filter: [pp=0x33]
    Opening video filter: [harddup]
    Read DOCS/HTML/en/codecs.html!
    Exiting...
    Interesting thing is, if i encode it to xvid .avi with mp3 audio the file is recognized.
    Encoding started on Sat Dec 10 20:56:34 CET 2005
    movtoy4m
    Copyright 2002-2005 Johan Lindstr??m
    All rights reserved. Used in ffmpegX under license.
    2005-12-10 20:56:35.009 movtoy4m[12744] CFLog (21): Error loading /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType: error code 4, error number 0 (Library not loaded: /System/Library/PrivateFrameworks/LiveType.framework/Versions/A/LiveType
    Referenced from: /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
    Reason: image not found)
    Input #0, yuv4mpegpipe, from 'pipe:':
    Duration: N/A, bitrate: N/A
    Stream #0.0: Video: rawvideo, yuv420p, 752x568, 25.00 fps
    Output #0, avi, to '/Users/MediaLabs/Desktop/3.avi.e.avi':
    Stream #0.0: Video: xvid, 752x568, 25.00 fps, q=2-15, 960 kb/s
    Stream mapping:
    Stream #0.0 -> #0.0
    bench: utime=0.312s
    video:126kB audio:0kB global headers:0kB muxing overhead 3.745077%
    /Library/WebServer/Documents/privat/ffmpegx/HSTEST.mov: could not find codec parameters
    Tia
    Michael
    I have tested the file a bit more and it seems to be a mencoder "problem".
    ffmpeg as codec works, mencoder not.
    It works choosing any possible ffmpeg option and .avi as container
    Hope that helps for "bugfixing"
    Michael
    Any help with the testfile is very welcome.
    After 2 Weeks testing and trieing i give up.
    I looks like ffmpegX cant encode this file
    "APPLE Intermed. Codec" to h264.
    Ave you tried the "decode with Quicktime" option in the "Options" tab?
    - macr0t0r
    When did email start feeling like work?
    Hi,
    there is NO "decode with Quicktime"
    Option if you encode to h.264.
    ? Er, that can't be right. (Fiddles with FFMPEGX).
    Ah, you are using the H.264(mencoder) encoder. Frankly, I wouldn't trust it anyway. There have been many reports of lip-sync problems with it, and it's not iPod-compatible anyway. Use the H.264(x264) encoder instead. It's more compatible, robust, and it allows decoding with Quicktime.
    Any particular reason you want to use the mencoder encoder?
    - macr0t0r
    Hi macr0t0r,
    yes yes used mencoder because ... uhmmmm. Eyesrolling and whistleing.
    Ohhkay, thanks
  1. Single .VOB file into working DVD?
    By AHK in forum Authoring (DVD)
    Last Post: 5th Sep 2011, 11:38
  2. TS file not working on VLC/TS DOCTOR/etc.
    By dickcruz in forum Software Playing
    Last Post: 23rd Jun 2011, 01:16
  3. How to download .swf file from orlive.com--- help plz
    By vediic in forum Video Streaming
    Last Post: 18th Aug 2010, 05:55
  4. Replies: 13
    Last Post: 7th Apr 2008, 17:58
  5. This file is Driving me Crazy! suggestions plz
    By k_oss_22 in forum Video Conversion
    Last Post: 18th Mar 2008, 23:40
