After I have finished editing my avi movie file in premiere pro, what is the easiest way convert it to mpeg2 for use in dvd lab pro.
I know I can use mpeg2 encoder with adobe premiere but it takes forever....?
thanks in advanced
If you want to encode to mpeg2, I advise you on using TMPGEnc for that, because it delivers a good encodes & other nice features.
take a look at http://www.videohelp.com/convert.
I have download TMPGENC, but when I browse and try to open my adobe premiere project in my folder, it says "cannot open or unsupported.
And when I select file type "avi" my file disappears".
Do I have to export it first?
I must be doing something really dumb.
Thanks in advance........[/url]
export to dv-avi in premiere or frameserve directly to tmpgenc using the Debugmode FrameServer or get a mpeg2 plugin for premiere and export directly to mpeg2.
SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 09:00 -
Convert an eDrawings File (.eprt) to AVI for Premiere Pro Editing
By foochuck in forum Video ConversionReplies: 9Last Post: 17th Jun 2008, 11:56 -
Help With Premiere Pro 2 (importing Screen Captured Avi File)
By paulinnorway in forum EditingReplies: 2Last Post: 15th Oct 2007, 10:19 -
Vob File has a aspect ratio of 704X480 in Dvd Lab Pro.
By mlong30 in forum Authoring (DVD)Replies: 4Last Post: 16th Jul 2007, 23:24 -
how do i put srt file in dvd lab pro?
By oilpourer in forum Authoring (DVD)Replies: 6Last Post: 1st Jul 2007, 18:20
Statistics
Newest guides
Latest tool updates
New media comments
