It looks like I will be sending in my pioneer 220 to a pioneer repair center to fix the loss of video signal from my vcr "flaw" (can this even be fixed). I was wondering what the turn around time would be? I have grown accustomed to using this to record everything and was hoping it would not take too long.
Results 1 to 12 of 12
The problem with the Pioneer 200 series is loose or faulty solder connections on the component out jacks. It's quite an easy repair for someone with a solder gun. Shouldn't be too much of an issue but I'd imagine Pioneer is going to charge you alot more than the .01 in solder they will be using.
Fortunately for me, my recorder is still under warranty. It actual paid off to hold onto my receipt. I still have 3 months left on my 1 year warranty.
I had to send my 420 in shortly after I bought it last Feb. It took about 3-1/2 weeks, but I called after 2 weeks and they said it was taking longer than usual because they had to wait for a part.
Be sure you keep the serial number. You'll need it if you have to call for anything after you send it. When I call to check on mine I didn't have the serial number, so it took a while for them to track down my recorder- they finally found it based on the name of the person who had accepted it when it was delivered to them.
no problems yet.
Well I got my recorder back a couple of days ago and of course I still get the random signal loss flaw
I can't tell if they did anything to fix it. It looks like they just repackaged it and sent it back to me. I am sure glad I waisted all that time converting my tapes and blowing $200 on a machine that cannot do what I bought it to do. I do not think I can even sell it on ebay. Who would want a recorder that can't dub tapes properly.
I was thinking of upgrading to a recorder with a hard drive but it looks like the only one in my price range would be from pioneer. Anyone want to recommend another model that is reasonably priced?
Maybe I will feel better after I do some bitching to a customer service rep. Hopefully I can at least find out if they did anything at all to try and fix my recorder.
Funny stuff.
Without a constant and potent signal my old Philips DVDR985 will cough out as well. It has done that since day one and I suspect your Pioneer will as well. I invested in better cables and a signal booster and my problems were solved. The best solution MUST have been better/shorter cables since I haven't used my cheapo Radio Shack signal booster for quite a while now.
i recently baught the lg rh7521w (hdd recorder) and works incredibly wellOriginally Posted by colt4523
$500 australian
I called customer support and they indeed said that they could not duplicate the problem and did nothing to fix it. Well, I was able to duplicate the problem right away. They could have at least called me stating that they could not find the problem.
Does anyone know a way that maybe I could fix this myself? I am steaming right now and it is pointless to ship it back to them describing the same problem. This is a known flaw right? Is it fixable?
An external TBC seems to correct the problem for me.Originally Posted by colt4523
I already have a full frame tbc, it does not help with my problem. It looks like my only solution is to write a dirty email to pioneer and buy a new recorder.
Pioneer DVD recorder
By cjones in forum Newbie / General discussionsReplies: 1Last Post: 11th Aug 2011, 06:14 -
Send DV through Firewire to a DVD recorder
By nlec in forum ProgrammingReplies: 16Last Post: 2nd Oct 2010, 02:56 -
Pioneer DVD recorder firmware
By jh76 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 11th Apr 2009, 02:03 -
Which HDD Recorder is better? Panasonic or Pioneer
By aim15011 in forum DVD & Blu-ray RecordersReplies: 15Last Post: 27th Dec 2007, 11:03 -
How can I send video out of my PC to a dvd recorder?
By pugvader in forum Newbie / General discussionsReplies: 8Last Post: 9th Aug 2007, 08:12
