How do you change a project from Non-Drop to Drop? and vise-versa?
Project 1: I batch capture fine with my DVC-Pro deck.
Project 2: A Drop frame tape was inserted, a Non-Drop frame was expected.
I assume I need to switch the drop frame settings.
Help!
Hi-
Apply Pulldown again, this time with -drop_frame true added. Or if using a GUI, check the appropriate box.
and vise-versa?
It's "vice versa". Apply Pulldown again, this time with -drop_frame false added. Or if using a GUI, check the appropriate box.
That's how you do it in software. I have no idea what you're using.
Opps, I'm sorry, I should have put AVID in the post instead of the Title.
You have to insert a tape and Add New Tape to the capture tool (adding a new tape resets to default settings of Non-Drop.)
And in your time code in the Bin, ; means Drop Frames and : means Non-Drop.
This deck is very strange ... its a Panasonic DVCPRO AJ-D230HP with firewire support.
My fault. I read AVID in the title, and then promptly forgot about it.
I don't know anything about hardware methods. Sounds like a job for edDV, the site expert on such things. If he (or someone else experienced with AVID) doesn't see this thread, why don't you PM him and ask him to have a look.
Drop frame and Non-Drop frame affects only timecode not the actual video.
Not many AVID high level users here. Best to try an AVID specific forum. If you don't have one, DMN forums index is a good place to start.
http://www.dmnforums.com/cgi-bin/wwuglistcategory.cgiRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Its cool, I knew that Drop and Non-Drop had nothing to do with the video.
I've used AVID for over a year, and I feel like I know only 25% of AVID.
All this time, I'd been using a transcoder (suck) and I just received my new digital deck a week ago. Our other two producers said they couldn't get Batch capture to work with XPress Pro because it asked for a Non-Drop tape.
Took me all of today to finally figure it out.
I will look at this site! I appreciate all of your help!!!
jvc gy-hm 700 drop frame
By seistro in forum Camcorders (DV/HDV/AVCHD)Replies: 2Last Post: 29th Apr 2012, 03:53 -
Dazzle 720x 480 Frame Drop
By genericman in forum DVD & Blu-ray RecordersReplies: 0Last Post: 28th Mar 2011, 10:37 -
HDV Video >>>>> Use Non drop frame or drop frame and why?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 3rd Nov 2010, 18:30 -
Converting drop frame timecode to non drop frame timecode, and vice versa
By picrade in forum ProgrammingReplies: 1Last Post: 1st Mar 2008, 04:22 -
Frame drop in firewire HDV transfer
By Dinu Bandyopadhyay in forum Camcorders (DV/HDV/AVCHD)Replies: 17Last Post: 19th Oct 2007, 11:29
