Hey guys.
So at the last few concerts I have been to I have made some video footage on my phone. When played back the audio is very high and distorts, BUT if I lower the volume on the output (phone speaker) it sounds fine and I can hear it and whatnot. I was just wondering what steps I need to take to lower the actual encoded volume of the file?
I was also wondering if there is something I can do to remove some of the background noise/sounds that are in there.
Any help would be extremely appreciated.
You could try Audacity. It's a freeware audio editor. Noise filtering can be difficult, depending on the type of noise, but you may be able to make some improvements.
I use Pristine Sounds to remove most tape hiss from some old cassettes I copied into my computer for burning to CD.
You simply sample a section of the file with no muisic to get the "noise" and then apply a filter to remove that noise from the file.
It also has other noise reduction techniques including a great noise filter for vinyl recordings - reduces rumble, surface clicks and pops etc
A functional demo is available from
http://www.alienconnections.com/downloads.htm
Good luck
Avisynth's "levels" function - 32-bit? Dithering?
By Asterra in forum Video ConversionReplies: 7Last Post: 5th May 2011, 00:57 -
What are Video "Profile Formats" or "Levels"?
By HanDuet in forum Newbie / General discussionsReplies: 2Last Post: 15th Mar 2011, 23:41 -
Deleting or softening a "creaking" noise in recital audio in Audacity
By MLK3329 in forum Video ConversionReplies: 5Last Post: 9th Oct 2010, 15:41 -
Nero failure burning "Audio & Data cd"
By spiritgumm in forum AudioReplies: 4Last Post: 15th Oct 2008, 16:25 -
AviSynth Levels - "operate in luma instead of RGB"?
By tat2jr in forum EditingReplies: 1Last Post: 11th Aug 2007, 07:58
Statistics
Newest guides
Latest tool updates
New media comments
