VideoHelp.com Forum
Results 1 to 13 of 13
  1. [url=http]text[/url] Denvers Dawgs's Avatar
    Buying new Desktop, comes with 1 250GB hardrive with OS on it. I do a fair amount of video editing. Should I partion my hard drive so the OS is seperate from rest of the video files? I was thinking giving the section with teh OS about 40GB, and the other being about 210GB.
    I have no idea how to partition a disc or if I should even do it. Should I just buy a 2nd drive and use that for video stuff?
    What We Do In Life, Echoes In Eternity....
  2. Member dipstick's Avatar
    Sure, you can partition it that way and yes, it's a good idea to keep OS away from important files. You can also get another HDD too.
    I like to keep my OS's on their own partition all by them selves on my primary HDD. I keep all data on seperate partition. My 2nd HDD and external HDDs only use one partition each.
    I stand up next a mountain and chop it down with the ledge of my hand........ I'm a Voodoo child.... Jimi Hendrix,
  3. Member isogonic's Avatar
    i keep my video on a 2nd HD-- which is also useful for storing stuff you want to keep, i reformat at least once a year
  4. Banned
    Server OS Drives are the only disks I partition. Desktops and Laptops do not need to be partitioned IMO. If separation is required I usually recommend two separate drives.
  5. DVD Ninja budz's Avatar
    I partition my primary hard drive in case WINDOWS becomes corrupted I can easily just reformat that partition and not lose anything else that is on it. I have 2 or more hard drives in my pc's and also have internal hard drives in external enclosures as well.
    I'd say use only 20-25 gbs of hard drive space for your OS. I only use that much space to install the OS on computers that I build.
  6. [url=http]text[/url] Denvers Dawgs's Avatar
    How would I go about partitioning my OS from the rest of the HDD. Do I need software, or can it be done through XP?
  7. Member rkr1958's Avatar
    I have a 15-GB partition on one my harddrives (the 120-GB one) for Windows & Applications. I use Restore-It on that partition and I use Norton Ghost once a week to make a image of it. Just last week, I did something stupid and corrupted that partition ... with my partition backups it took me 5-minutes to get back to where I was. In my opinion its a good thing to keep your O/S & applications in a small partition away from everthing else. It's a better idea if you routinely image that partition. This strategy has saved me several times.
  8. Member rkr1958's Avatar
    I use Partition Magic 8.0 for all my partitioning and formatting needs ... I got a copy off of ebay almost 2-years ago for around $20. It'll let you do a non-destructive partitioning of a drive. Well worth the money.
  9. [url=http]text[/url] Denvers Dawgs's Avatar
    So I could do this with my computer as is and won't lose any files that are on the HDD. Also, after I partition the HDD, will I be able to drag folders Videos/pix, that I want to keep onto the new empty partition?
  10. DVD Ninja budz's Avatar
    As a precaution I would backup whatever you have before you partition your hard drive. Yes you'll be able to drag and drop whatever you want into the new empty partition.
  11. [url=http]text[/url] Denvers Dawgs's Avatar
    After partitioning the hard drive in to (2)partitions (OS and Video editing) Will anything done on the video editing portion afffect the OS? Is a partition like having another HDD?
    Would it just be easier to pick up say an 80GB HDD and use that for my OS? and use the original HDD for my editing? If so, How would I go about putting the OS and all the drives/programs onto the 80GB drive. Most new computers don't come with replacement discs anymore, or atleast my previous one only came with System Restore and System Recovery Built into a partition.
  12. Always Watching guns1inger's Avatar
    Partition is basically creating a virtual drive. The OS treats each partition as if it were a drive. For management of the space, especially speration of the OS partition from the working area, it is worth considering.
    If you are editing a lot of video, I would put in a second, and maybe even third drive, as there can be preformance gains sending data from physical drive to physical drive (depending on configuration) that can not be had from partitions.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  13. [url=http]text[/url] Denvers Dawgs's Avatar
    What do you mean by this? I would just be setting it up with a second drive in the available 2nd HDD slot.
  1. Partition HDD
    By videobread in forum Computer
    Last Post: 16th Dec 2011, 11:22
  2. Replies: 4
    Last Post: 30th Nov 2011, 21:20
  3. Replies: 8
    Last Post: 31st May 2011, 16:07
  4. Replies: 9
    Last Post: 20th Nov 2009, 11:22
  5. Partition Problem
    By phodot in forum Computer
    Last Post: 19th Nov 2008, 23:52
