I have an avi file that uses .h264 and has hard subs. I know you can use subrip to convert .vob sub files to .srt. I'm just wondering, does subrip support .h264, because when I open the video file I see nothing.
It supports avi's, shouldn't matter what video codec they use as long as you have a decoder installed. Appears to decode via VfW to, so just because you can play the file back doesn't mean anything. Install a recent ffdshow build and make sure that AVC decoding is enabled for VfW.
can you open it in virtualdub?
if not install latest ffdshow and enable avc/h264 under vfw(video for windows).
edit:i'm too slow...
Combine/merge two subrip srt of different languages into one
By leesing2k in forum SubtitleReplies: 4Last Post: 5th May 2012, 00:55 -
hard encoding .srt subs to avis
By ninmario4life in forum SubtitleReplies: 3Last Post: 8th Nov 2009, 15:35 -
SubRip does not want to save the resulting .srt file.
By salmond in forum SubtitleReplies: 4Last Post: 28th Aug 2009, 20:43 -
Fixing a Unicode SRT file from SubRip.
By bizzybody in forum SubtitleReplies: 0Last Post: 5th May 2009, 02:51 -
Rip hard-coded subs from avi - VirtualDub filter and SubRip problems
By jujuandhuhu in forum SubtitleReplies: 4Last Post: 25th Oct 2008, 14:16
Statistics
Newest guides
Latest tool updates
New media comments
