VideoHelp.com Forum
  1. Hi all,
    I've just started using the Womble MPEG Video Wizrad and am very pleased with it so far.
    Can't work how to do one thing though.
    I can trim my mpg file at each end of the file, no problem, but want to trim out segments of the mpeg file (editing out commercials etc).
    I know it's a dumb question, but how do you do this ?
    place the playback head on the timeline where you want to cut, and click the scissors icon on the right, or press CTRL+Q to spilt the clip.
  3. Member ZippyP.'s Avatar
    Set the in and out points then cut, details here: http://www.videoforums.co.uk/guide-edit-vob-mpeg-48.htm
  4. To edit out commercials, do the following:
    1. Open your original file in Input window
    2. Mark In/Out (using I and O keys on your keyboard) portion of the file between commercials and drag it to timeline with Camera icon
    3. Repeat step 2 for each part of your original file you wish to have in the final output
    4. Press E on your keyboard to export your new commercial-free video to a new file
    That's all. When exporting file, make sure to use Automatic under 'Save as type'. This will ensure that your file is exported in its original quality, without any audio/video re-encoding.
  5. Thankyou for the quick reply.
  1. Replies: 3
    Last Post: 29th Jan 2009, 07:44
  2. Womble video wizard mpeg dvd
    By Remyisme in forum Newbie / General discussions
    Last Post: 18th Nov 2008, 14:47
  3. Frameserving Womble Mpeg Video Wizard
    By tmw in forum Video Conversion
    Last Post: 1st Nov 2008, 08:53
  4. Womble MPEG Video Wizard destroys audio?!
    By noemi7 in forum Editing
    Last Post: 16th Jun 2008, 10:18
  5. settings for Womble MPEG Video Wizard DVD
    By Vril-ya in forum Editing
    Last Post: 20th May 2008, 19:18
