Iv bin using svcd now for the last year or so with no problems at all, my hard drive packed up the other day so i had to do a fresh install, so im using the new version of svcd and when im convertin avi files i get this error....can anyone help please?
Thread: ffmpeg.exe error
Can you post your log file where this happens please?
svcd is not commin up with the error, i get the windows error box.......
ffmpeg.exe has encountered a problem and needs to close
when i close the box svcd creates the dvd that it processed, usually around the 12% mark this error happens, it only does this wiv avi files, any other is fine.
Is it all avi files or just one particular one?
its any avi file that i try to convert, can i get hold of the version before the latest 1, gunna see if it does the same?
I suspect it is the old overheating issue:
http://www.videohelp.com/forum/viewt...highlight=dust
http://www.videohelp.com/forum/viewt...&highlight=cpuSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Need mencoder.exe and ffmpeg codecs
By swkenney in forum Newbie / General discussionsReplies: 7Last Post: 6th Dec 2010, 19:41 -
ffmpeg.exe has stoped working
By downer in forum SVCD2DVD & VOB2MPGReplies: 32Last Post: 4th Jan 2010, 04:03 -
ffmpeg.exe has stopped working error when trying to add asset
By skeet09 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 27th Oct 2009, 15:15 -
ffmpeg.exe - Target file size?
By Gew in forum Video ConversionReplies: 0Last Post: 25th Feb 2009, 13:46 -
DVD Flick error message "ffmpeg.exe has stopped working"
By stewiegriffin711 in forum Authoring (DVD)Replies: 4Last Post: 17th Aug 2008, 07:20
