VideoHelp.com Forum
  1. Module C:\WINDOWS\SYSTEM\Code-Lock.ocx failed to register. HRESULT
    -2147023739 Contact your support personnel.
    Running windows 98se, trying to install SVCD2DVD 2.0
    Ignore the error and run SVCD, get the following error:
    Version: SVCD2DVD 2.0
    Build: 2.0.2146.38147
    Type: System.Runtime.InteropServices.COMException
    Source: System.Windows.Forms
    Message: Class not registered
    InnerException:
    StackTrace: at System.Windows.Forms.AxHost.CreateInstance()
    at System.Windows.Forms.AxHost.GetOcxCreate()
    at System.Windows.Forms.AxHost.TransitionUpTo(Int32 state)
    at System.Windows.Forms.AxHost.CreateHandle()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.AxHost.EndInit()
    at x3284ccece41ee22b.x2f5590cb48bb0c53.x85601834555fb 7d5()
    at x3284ccece41ee22b.x2f5590cb48bb0c53..ctor()
    at x3284ccece41ee22b.x2f5590cb48bb0c53.xc447809891322 395(String[] xce8d8c7e3c2c2426)
  2. Still does not work. My system is win98se. All of those errors involved
    XP and SP2 issues. Any clues??
    Thanks,
    Met
  3. Do you .NET installed?
    Dwight
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
    - Herm Albright
    www.martialconcepts.com
  4. Member ChrissyBoy's Avatar
    Can you try installing the VB runtime:
    http://www.microsoft.com/downloads/d...displaylang=en
    It would seem the 98 doesn't install this be default.
    After installing that can you install S2D again?
  5. That did the trick..
    Thanks,
    Met
  1. Zwei-Stein installation error.
    By sjs in forum Editing
    Last Post: 1st Feb 2011, 14:30
  2. Installation error
    By johnsonk in forum ffmpegX general discussion
    Last Post: 14th Aug 2009, 11:05
  3. Installation Error In Leopard
    By Lefty! in forum ffmpegX bugs and suggestions
    Last Post: 6th Dec 2008, 04:14
  4. vegas 6.0 installation error
    By scd250 in forum Software Playing
    Last Post: 27th Feb 2008, 21:09
  5. Installation error -
    By ruggerjvd in forum ffmpegX bugs and suggestions
    Last Post: 12th Nov 2007, 09:06
