I've tried using a batch method that I read here but when I use ifo edit to do this it wouldn't change it. What can I do?
Results 1 to 9 of 9
Got a link to this "batch method" of which you speak ?
If in doubt, Google it.
I have done this many times. The quickest and easiest method is to use DGPulldown. I have however run into situations where that will not work, so I have had to take the longer route and use a Phillips DVD player and record to my Pioneer dvd recorder, then transfer to computer to re-author.
There are other methods which you can use, but they are time consuming because you must not only change the framerate, but also the resolution AND the audio...that is where most people screw it up because the audio gets out of sync.
Sorry Jimmalenko I meant "Patch Method" here is the link http://www.videohelp.com/forum/viewtopic.php?t=221928. Also I don't know exactly what kind of files to use for dgpulldown?
I use DVDShrink to rip the DVD, but you must rip movie only, and you must rip to only one VOB file (you must select that in the preferences options)
Then I feed the large VOB file into VSO Divx to DVD Converter.
Select force PAL 25 Fps and press convert.
Where do you find that "Select force PAL 25 Fps and press convert" feature?
It's pretty easy to spot on the VSO Divx to DVD interface. One of the few options you can set, actually. Drop-down selector box, off to the right I believe. Been a while so I'm going from memory.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
The easiest by far is NeroVison Express 3 (set for NTSC). If it's a disc simply 'import disc', if they are VOB's (or any vid files) 'add' them, create some chapter stops, adjust the bitrate if needed and burn. You will lose any original menus and subtitles though.
That's for the freeware version.Originally Posted by sacajaweeda
The new payware version has a whole section menu up near the File menu with 8 tabs devoted to settings, and this particular setting is under the "TV Format" tab now.If in doubt, Google it.
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 15:17 -
Recommendations for AVISYnth NTSC video (60i) to PAL video (50p)
By csdesigns in forum Video ConversionReplies: 7Last Post: 3rd Feb 2009, 10:33 -
PAL Video Cassette Recorder or [Multisystem VCR] for PAL->NTSC playback
By quantass in forum Newbie / General discussionsReplies: 10Last Post: 12th Dec 2008, 13:47 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 11:30 -
How tell If Video is Pal Or Ntsc??
By masterpkg in forum Newbie / General discussionsReplies: 2Last Post: 30th Jun 2007, 22:53
