VideoHelp.com Forum
Results 1 to 11 of 11
    Hi,
    I'd appreciate it if anyone would let me know of an app or way to save .swf movies. The ones I'm looking to save are embedded in a page when I click the link...a small window opens up in the browser and the file is streamed (embedded on page).
    Thanks.
  2. "IE 7 and Vista remind me of the old definition of a giraffe: it's a horse designed by a committee."
    Sorenson software is excellent piece of software for creating SWF files from video sources like AVI / MPG etc.
    For saving SWF files embeded on webpages you should try to use this cutie:
    http://www.flash-screen.com/flashsaver/
    Regards
    Is Flash Saver OSX compatible? It doesn't seem so from that link.
    This is a long shot and probably of no use to you, but worth mentioning anyhow. The latest versions of the iCab 3 beta have a cache browser that makes it easy to locate cached files and do whatever you want with them.
    When the next public preview gets released it will probably include the cache browser. Something you might want to try out if you haven't found a better solution by that time.
    Of course, if you have access to the betas then this info is all you probably need to fish those .swf files out.
  6. Or use Snapz Pro to record them as they play.
  7. If you are using Safari, go to Window > Activity. It will bring up a list of all the assets on the page you are currently viewing. Find the .swf, double-click... And it will open in a new window. Then save it.
    Just a FYI.
    As I touched on before, a new Public Beta of iCab is now available and includes the new cache browser. You can get it here.
  9. How about a reversable method? Converting a .swf to a Quicktime .mov movie for example? Would love to know the best way to do that...I do have Snapz X Pro but it always yields very stupid sized files. (800mb for 4 minutes of video?...maybe theres a setting Im not using you can advise on?).
    Mucx
    I just downloaded a demo of SnapzPro 2, and with a little fiddling
    captured a Flash video. Impressive. Dunno if I want/need the
    capability enough to pay Ambrosia the $79 to remove the "unregi-
    stered copy" blurb that's all over the final product.
    Firefox with AdBlock and Flasblock works, too. I had a friend send me a Christmas email with a Flash attachment. Normally I block all Flash, but this one I actually wanted.
    When I clicked the link it took me to a website for greeting e-cards and the Flash object appeared and was blocked, which it should have been. To save and view it I clicked "F" once to enable Flash for this ad, then Adblock tab that appears once to get the true url of the Flash file, Apple-c to copy, then opened iGetter, my download manager, and Apple-v to paste the url, and told iGetter to download the file to the desktop. iGetter can send cookies as your 'browser' so the website doesn't think its handing off the file for download.
    SWF files can be played by Quicktime. I don't have Flash player for OS X because I hate Flash too much. I have also removed the Quicktime and Flash plugins from Firefox, because otherwise they overrule Firefox and will not let you save the file. I also absolutely block QT from all network connections (with Lil Snitch) to force it to behave and to prevent it from calling home and sending ads to my player.
  1. How to Save JPG / BMP output from *.swf files?
    By devilcoelhodog in forum Newbie / General discussions
    Last Post: 14th Oct 2010, 02:32
  2. swf file to youtube
    By troyvcd1 in forum Video Conversion
    Last Post: 4th Nov 2009, 01:57
  3. mpeg2enc issue with OSX 10.5 or source file
    By ca1amity in forum ffmpegX general discussion
    Last Post: 10th Jun 2008, 00:48
  4. SWF file re Flash
    By rotuts in forum Mac
    Last Post: 4th Mar 2008, 12:46
  5. SWF mx, swf 3 ( legacy ), and FLV, whats the difference
    By theewizard in forum Newbie / General discussions
    Last Post: 4th Feb 2008, 23:15
