    I've been trying to burn a movie with Nero Express, and have had little success. I'm using Nero 6.0. I first ripped it with DVD Shrink, and then set it to burn with Nero. It burns the whole thing, until the very end when, at 100%, it suddenly gives me this message.
    Invalid field in command.
    Could not perform end of Disc-at-once.
    Burn process failed.
    I thought maybe I'd done something wrong with the burning process when I was transfering the files into Nero, so I did it again. Same message. I thought trying to use Nero, rather than Nero Express, would work, and I found this tutorial at http://www.dvdshrink.info/nero-udf-iso.php and followed it to a T. Still the same message. I don't know what to do.
    I saw in this post on the forum at http://www.videohelp.com/forum/archive/t275157.html that using DVDDecrypter might be my best bet, but I couldn't find anything anywhere to tell me why Nero wouldn't be working, except that if I go back to an earlier version of it it should work. I hate to keep wasting DVDs as money is rather tight right now.
    I've included the log, I don't know if anyone can help but any insight is greatly appreciated. Should I just got with DVDDecrypter and hope that works? Or is there a specific setting in Nero that is causing this?
    The log:
    Windows XP 5.1
    IA32
    WinAspi: -
    ahead WinASPI: File 'C:\Program Files\Nero\Wnaspi32.dll': Ver=2.0.1.56, size=163910 bytes, created 4/2/2003 8:13:44 AM
    Nero version: 6.0.0.0 (Nero Express)
    Recorder: <PIONEER DVDRW DVR-K15> Version: 1.11 - HA 1 TA 0 - 6.0.0.0
    Adapter driver: <atapi> HA 1
    Drive buffer : 2000kB
    Bus Type : via Inquiry data (1) -> ATAPI, detected: ATAPI
    Connected to MMC as unknown drive with class-nr : 1
    Drive is autodetected - recorder class: Std. MMC recorder
    CD-ROM: <PIONEER DVDRW DVR-K15 >Version: 1.11 - HA 1 TA 0 - 6.0.0.0
    === Scsi-Device-Map ===
    DiskPeripheral : TOSHIBA MK4025GAS atapi Port 0 ID 0 DMA: On
    CdRomPeripheral : PIONEER DVDRW DVR-K15 atapi Port 1 ID 0 DMA: On
    AutoRun : 1
    Excluded drive IDs:
    CmdQueuing : 1
    CmdNotification: 2
    WriteBufferSize: 57671680 (0) Byte
    ShowDrvBufStat : 0
    EraseSpeed : 0
    BUFE : 0
    Physical memory : 382MB (391664kB)
    Free physical memory: 29MB (29964kB)
    Memory in use : 92 %
    Uncached PFiles: 0x0
    Use Static Write Speed Table: 0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Disabled (0)
    28.11.2005
    UDF/ISO compilation
    11:47:33 PM #1 Phase 112 File dlgbrnst.cpp, Line 1818
    DVD-Video files reallocation started
    11:47:34 PM #2 Phase 114 File dlgbrnst.cpp, Line 1818
    DVD-Video files reallocation completed (no file modified)
    11:47:34 PM #3 Text 0 File Isodoc.cpp, Line 5451
    Iso document burn settings
    Determine maximum speed : FALSE
    Simulate : FALSE
    Write : TRUE
    Finalize CD : TRUE
    Multisession : FALSE
    Burning mode : DAO
    Mode : 1
    ISO Level : 1 (Max. of 11 = 8 + 3 char)
    Character set : ISO 9660
    Joliet : TRUE
    Allow pathdepth more than 8 directories : FALSE
    Allow more than 255 characters in path : FALSE
    Write ISO9660 ;1 file extensions : TRUE
    11:47:34 PM #4 Phase 111 File dlgbrnst.cpp, Line 1818
    DVD-Video files sorted
    11:47:34 PM #5 Text 0 File Reader.cpp, Line 118
    Reader running
    11:47:34 PM #6 Text 0 File Writer.cpp, Line 127
    Writer PIONEER DVDRW DVR-K15 running
    11:47:34 PM #7 ISO9660GEN -11 File geniso.cpp, Line 3814
    First writeable address = 0 (0x00000000)
    11:47:34 PM #8 ISO9660GEN -11 File geniso.cpp, Line 3814
    11:47:34 PM #9 Text 0 File Burncd.cpp, Line 3081
    Turn on Disc-at-once, using DVD media
    11:47:38 PM #10 Text 0 File DlgWaitCD.cpp, Line 224
    Last possible write address on media: 2295103 (510:01.28)
    Last address to be written: 2286127 (508:01.52)
    11:47:38 PM #11 Text 0 File DlgWaitCD.cpp, Line 229
    Write in overburning mode: FALSE
    11:47:38 PM #12 Text 0 File DlgWaitCD.cpp, Line 1688
    Recorder: PIONEER DVDRW DVR-K15, Media type: DVD+R
    Disc Manufacturer ID: YUDEN000, Media Type ID: T02, Product revision number: 0
    Disc Application Code: 0, Extended Information Indicators: 3
    11:47:38 PM #13 Text 0 File ThreadedTransferInterface.cpp, Line 757
    Setup items (after recorder preparation)
    0: TRM_DATA_MODE1 (CTransferItem)
    2 indices, index0 (150) not provided
    original CD pos #0 + 2286128 (2286128) = #2286128/508:1.53
    relocatable, CD pos for caching/writing not required/required, no patch infos
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286128 blocks [PIONEER DVDRW DVR-K15 ]
    11:47:38 PM #14 Text 0 File Burncd.cpp, Line 3318
    Recorder and media-info
    Burning to PIONEER DVDRW DVR-K15 on a DVD+R media
    11:47:38 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 910
    Prepare recorder PIONEER DVDRW DVR-K15 for write in cue-sheet-DAO
    DAO infos:
    MCN:
    TOCTYPE: 0x0 Session Closed, CD fixated
    Tracks 1 to 1:
    TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 387330048
    11:47:39 PM #16 Phase 24 File dlgbrnst.cpp, Line 1818
    Caching of files started
    11:47:39 PM #17 Phase 25 File dlgbrnst.cpp, Line 1818
    Caching of files completed
    11:47:39 PM #18 Phase 36 File dlgbrnst.cpp, Line 1818
    Burn process started at 2.4x (3,312 KB/s)
    11:47:39 PM #19 Text 0 File ThreadedTransferInterface.cpp, Line 2104
    Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
    11:47:39 PM #20 Text 0 File Cdrdrv.cpp, Line 7827
    ---- DVD Structure: Physical Format Information (00h) ----
    Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
    Book Type: DVD+R (10), Part Version: 1
    Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
    Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
    Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
    Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
    End Physical Sector Number of Data Area: 26053F h
    End Sector Number in Layer 0: 0 h
    Data in Burst Cutting Area (BCA) does not exist
    Media Specific:
    00 03 59 55 44 45 4E 30 - 30 30 54 30 32 00 38 23 ..YUDEN000T02.8#
    54 37 10 02 4E 72 02 8C - 63 16 16 0B 0B 0A 0A 01 T7..Nr..c.......
    19 1B 0C 0C 0C 0D 01 00 - 00 00 00 00 00 00 00 01 ................
    11:47:39 PM #21 Text 0 File dlgbrnst.cpp, Line 1678
    Set remaining time: 23:51,270 (1431270ms) -> OK
    11:47:39 PM #22 Text 0 File DVDPlusRW.cpp, Line 513
    Start write address at LBA 0
    DVD high compatibility mode: Yes
    12:12:02 AM #23 Text 0 File WriterStatus.cpp, Line 112
    <PIONEER DVDRW DVR-K15 > start writing Lead-Out at LBA 2286128 (22E230h), lenght 0 blocks
    12:12:03 AM #24 Text 0 File ThreadedTransfer.cpp, Line 227
    all writers idle, stopping conversion
    12:12:04 AM #25 SCSI -1066 File Cdrdrv.cpp, Line 1151
    SCSI Exec, HA 1, TA 0, LUN 0
    Status: 0x04 (0x01, SCSI_ERR)
    HA-Status 0x00 (0x00, OK)
    TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
    Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
    Sense Code: 0x24
    Sense Qual: 0x00
    CDB Data: 0x5B 0x01 0x01 0x00 0x00 0xFF 0x00 0x00 0x00 0x00 0x00 0x00
    Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0E
    0x00 0x00 0x00 0x00 0x24 0x00
    12:12:04 AM #26 SCSI -1176 File Cdrdrv.cpp, Line 1151
    Sense Code: 0x72
    Sense Qual: 0x03
    CDB Data: 0x5B 0x01 0x06 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    0x00 0x00 0x00 0x00 0x72 0x03
    12:12:04 AM #27 Text 0 File dlgbrnst.cpp, Line 1678
    Set remaining time: 0:00,000 (0ms) -> OK
    12:12:04 AM #28 CDR -1066 File ThreadedTransferInterface.cpp, Line 1594
    12:12:04 AM #29 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1594
    12:12:04 AM #30 Text 0 File dlgbrnst.cpp, Line 1678
    12:12:04 AM #31 Text 0 File dlgbrnst.cpp, Line 1678
    12:12:04 AM #32 Phase 38 File dlgbrnst.cpp, Line 1818
    Burn process failed at 2.4x (3,312 KB/s)
    Existing drivers:
    File 'Drivers\PXHELP20.SYS': Ver=2.03.27a, size=20576 bytes, created 1/26/2005 4:03:00 AM (Prassi/Veritas driver for win 2K)
    File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 8/3/2004 7:59:44 PM (Adapter driver for rec)
    Registry Keys:
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
    Anyone have any ideas? Thanks so much!
    You should be telling DVD Shrink to automatically burn the files with Nero. That way there is no possible error that could occur as when manually transfering the dvd files into Nero.
    I would simply use Shrink to create an ISO and Decrypter to burn the ISO to a DVD. After the 1st cycle, it is an automatic porcess provided you have two drives to house the original and the blank disc. I get 100% success on three different drives and all sorts of media using that method.
    No DVD can withstand the power of DVDShrink along with AnyDVD!
  3. Member Krispy Kritter's Avatar
    My first thought would be hardware failure because the drive is reporting sense errors.
    I would also question why it is attempting to burn at 2.4x (assuming you are using quality media that is rated above 2.4x). This is either a software issue, the drive doesn't like that type/brand of media, or related to the sense error.
    Have you swapped or installed this drive AFTER installing Nero?
    Google is your Friend
  4. Member mats.hogberg's Avatar
    I'd recommend just creating an ISO with DVDShrink, then burn ISO with DVDDecrypter.
    /Mats
  1. Burn Process failed at 8X. using nero 7 - MINi DV to DVD
    By kanda in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 22nd Dec 2006, 22:33
  2. Nero: BUrn Process Failed? plz help...
    By tmac2085 in forum Newbie / General discussions
    Last Post: 29th Jan 2005, 13:15
  3. DVD burn process failed using nero
    By pido in forum Media
    Last Post: 11th Nov 2004, 03:59
  4. Nero...Could not perform fixation burn process failed
    By MtBuckley46 in forum Newbie / General discussions
    Last Post: 20th Aug 2002, 22:58
  5. Nero - Burn process failed
    By Duddi in forum Authoring (VCD/SVCD)
    Last Post: 24th Jul 2002, 16:07
DVDFab Blu-ray Copy lets you backup Blu-rays to Blu-ray or MP4 for Media players. More info or download trial!
About   Advertise   Forum   RSS Feeds   Statistics   Tools
