Hi,
I just got this at walmart for 68 dollars. My only problem is that I cant backup a dvd from another dvd player.
It says copyright protected.
It is not a crime to backup a copy for yourself. Is there a way I can turn this off?
Thanks,
Greg
Thread: Cyberhome dvr 1200
Mostlikely the output ports (Audio / Video) are being protected (for lack of better term) by MacroVision.
Search on MacroVision for a better understanding, and to defeat it you'll need a little black box that sits between the units and removes the MacroVision protection.
For informational purposes, here's an example of a black box you'll need :
http://www.varitech.nl/index_en.htm?...r_en/index.htm
Sabrowww.sabronet.com - It's all you need...to know
Can anyone recommend a macro descrambler box? What works best that I can buy in america?
Have you tried the Hack for this Recoder yet? I got one afew days ago and will be testting it.
Theres a hack to disable macros for this model? That would be great if you could post it.
I would really appriciate it.
There is no hack for the Cyberhome or the ilo 05 which is Cyberhome.
If trying to copy protected media, you have the wrong recorder
You will spend a lot of money and have marginal results with a BOX
Any one with a non working cyberhome dvr-1200 or 1600 will buy your remote
By therd3 in forum Newbie / General discussionsReplies: 0Last Post: 21st Sep 2010, 00:21 -
problem with cyberhome ch-dvr player/recorder
By kayjay3k in forum Newbie / General discussionsReplies: 1Last Post: 20th Jan 2010, 16:27 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 19:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 17:26 -
Need firmware for CyberHome DVR-1200 (MU)
By Man In Black in forum DVD & Blu-ray RecordersReplies: 7Last Post: 25th Jul 2009, 21:46
