VideoHelp.com Forum
Results 1 to 9 of 9
    I just got the Samsung R120 recorder. Need to find what DVD-R will work best for it. Is the -RW worth it?
    I plan to switch all my VHS to DVDs.
    I have heard certain brands work best for certain DVDr.
    I got the maxell DVD-R that are made in taiwan. Are they any good? Samsung recommends Maxell.
    Thanks for your input!
  2. Member FulciLives's Avatar
    I would only use Taiyo Yuden DVD-R for the DVD-R format. They can be bought on-line for a fairly good price (considering how good they are) from RIMA.COM
    For DVD-RW I have been using Maxell DVD-RW discs that I have bought at WALMART. They come in a 5 pack (with a full DVD case) for only $7.77
    DVD-RW is good if you want to copy it to the computer and re-author or for "time shifting" when you plan on watching something once then delete it.
    - John "FulciLives" Coleman
    I see you're cross posting.
    http://www.videohelp.com/forum/viewtopic.php?t=285755
    Good media list for USA as of November 2005
    Sony brand DVD+R (made in Japan) = YUDEN media
    Sony brand DVD+R (made in Taiwan) = SONY media
    Sony brand DVD-R (made in Japan) = TY or SONY media
    Fuji brand DVD+R (made in Japan) = YUDEN media
    Fuji brand DVD-R (made in Japan) = TY media
    Verbatim brand DVD-R (made in Taiwan) = MCC media
    Verbatim brand DVD+R (made in Taiwan) = MCC media
    Maxell brand DVD-R (made in Japan) = MXL media
    Maxell brand DVD+R (made in Japan) = MAXELL media
    TDK brand DVD-R (made in Taiwain) = TDK media
    Pick one. Best Buy, Staples, Office Depot, Walmart, Fry's and OfficeMax are all fine places to pick up some of these discs. About $15-20 per 50 pack on sale. New sale each week it seems.
    For more advanced media quality info, read www.nomorecoasters.com
    I"m curious as to why you left off the Sony 8x DVD-R made in Taiwan; I've seen no difference in SONY08D1 made in Japan from that made in Taiwan.
    Oversight mostly. That and the fact that I've not seen any Sony DVD-R from Taiwan lately.
  6. Member FulciLives's Avatar
    Normally I wouldn't buy MADE IN TAIWAN media but I did buy a 25 pack of SONY DVD-R discs that was only $8.99
    It has the SONY08D1 media code. So far I've burnt 2 discs at 4x (it is rated up to 8x) and I seem to be getting good burns (I tested both with those Nero Tools) but how good they are time will tell.
    I just couldn't pass up the price and needed some discs quick as well.
    I have a Samsung R120. I have used the Fuji 2x DVD-RW with great success. I do my editing at the pc level. HOWEVER; just to test my Samsung when I first unboxed it, I ran tests using three brands of DVD-R I had on hand at the time. Sony (SONY08D1), Fuji (TYG02) and Verbatim (MCC 02RG20) all worked for me with no issues.
    Hello Onesickpup,
    What speed did you recorded on the 3 brand of DVD-R?
    In the manual it says 4x but most of todays DVD-R comes in 8x or 16x.
    Also do you have issues with the chapters that result in 1 sec glitches every 5 mins?
    When did you buy the DVD maybe this issue was on older R120 and have been addressed if you don't see this issue.
    Thanks!
    All three of those media types are 8x DVD-R. Honestly, I have no idea what speed the recorder burns at ( Never read enough of the manual to even know!!!)
    I pretty much exclusively stick to XP and SP recording mode for most of what I do. With the LSI encoding chip this thing does very well at those rates.
    Sorry! Can't answer your question on the chapter glitch you refer to. I have never noticed it, but I cap and then edit on my pc. I don't import any chapter points to the pc. I'll try to watch for it and I'll post back if I find out anything. May be awhile as I don't have any projects going currently.
    Almost forgot - purchased my R120 in early September when it was on special at my local Bestbuy. It's not a Pioneer or JVC - but it does a pretty decent job on vhs transfer and digital cable time-shifting in xp and sp modes.
  1. Samsung DVD-R120
    By web_maven in forum DVD & Blu-ray Recorders
    Last Post: 21st May 2008, 09:03
  2. Re:Samsung DVd-R120
    By malteser66 in forum DVD & Blu-ray Recorders
    Last Post: 4th Feb 2008, 14:43
  3. NEED Region Free Hack for Samsung DVD R120
    By arctul in forum DVD & Blu-ray Players
    Last Post: 12th Dec 2007, 09:09
  4. Region Free Samsung DVD R120
    By arctul in forum DVD & Blu-ray Recorders
    Last Post: 11th Dec 2007, 12:08
  5. samsung dvd-r120 freezes
    By wschw in forum Newbie / General discussions
    Last Post: 27th Jul 2007, 14:34
