Just bought dvdv811x-03 in Walmart. It has divx feature. Anyone knows the code to get into region setup screen? I tried codes for previous models. No good. Help!
Thread: diamond vision dvdv811x-03
Hey just bought the same player. Thought I'd give some specs as it's an excellent price.
Plays VCD, SVCD.
Plays DivX3 all bitrates (slight stutter on 6000kbs sample)
Xvid DivX4, 5 everything except GMC with warp points (plays without) tried wide variety of bitrates and codecs all good.
Plays every avi container on the DivX test cd v2 but not with full functionality. It picks up multiple audio and video streams fine, but won't detect chapters or menues
Also had stutter problems with multi-channel + multi audiostream sample. Although either one by itself plays fine.
It won't play Mpeg4 AVC or WMV9.
Plays well on all media I tried. For DVD Verbatim, Sony, Ritek and TDK.
For CD I tried at least a dozen brands from good to cheap with no problems.
For Audio all forms of mp3 palyed perfectly. WMA9 Pro played WMA9 Sdt did not.
AAC did not.
Ogg Vorbis did not.
DTS 5.1 did not.
Wish I could get the menus working, but all in all I'm pretty happy.Wow!
The box said 4 to 6 years, and I put the puzzle
together in 3 weeks.
I grabbed this player as well.
WOW...$50.00cdn and it will play everything I've thrown at it...all xvids, no issues....will probably play a ham sandwitch if you can get it in the drive.
I'm totally impressed and happy with this player todate.
cheers
Hi,
I just p/u diamond vision 811x-03 from wall-mart ,but can't make to play dvd from europe, anyone knows how to make it region"0"
thanx :
SEARCH,LEARN AND SHARE
All of my DVDs are region free, so I can not test this:Originally Posted by klos07
|Open the tray and hit 9999 with the remote then press ENTER|
This works on other Diamond vision players.
_____________________________________
AMD Athlon 1600+ XP (1.4 GHz) CPU
MSI 266Pro 2 (with Raid controller)
Matrox 7200 rpm (2 disk 40G and 80G)
512 Mb DDRam
AIW 128 Pro PCI with 16Mb SDRAM on it.
HP DVD weiter 100i
VCS Diamond 7.0.29 Echoes
By Nagashi in forum AudioReplies: 0Last Post: 12th Jan 2012, 07:23 -
Diamond VStream any feedback?
By halekon in forum Media Center PC / MediaCentersReplies: 1Last Post: 17th Jul 2011, 12:35 -
Diamond VD500 - only encodes 10 min
By muscledoug in forum CapturingReplies: 2Last Post: 20th Mar 2011, 12:58 -
Trouble With Diamond VC600 and OneTouchGrabber
By ChaoticSerenity in forum CapturingReplies: 0Last Post: 8th Oct 2010, 15:44 -
Diamond vision help No disc!
By cripboy in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Aug 2007, 10:49
