Hi,
I have .VOB files that I'd like to put on a DVD, as it is DVD ready but I can't find the right software.
I did use Nero, where I could just put the .VOB files in the video folder and bingo DVD Burned.
However I recently updated Nero and it's not letting me do that any more.
Any ideas on how it can be done, what program is best to use?
thanks
imgtool classic and imgburn
or
copytodvd
or
http://www.videohelp.com/guides.php?...lect=3;25#3;25
Do you have all the other files you need as well - .IFO, .BUP etc ? or just some vobs you found somewhere ?
VOBs do not, on their own, a DVD make.
yes it's with the other files as well, all ready to burn.
you could run it through DVDShrink with a no compression setting. It will either burn it using Nero or you can create an ISO to burn with DVDDecrypter
anyway what is Nero doing when it doesn't let you? Are you using the Nero Startsmart or Nero Burning Rom interface?
maybe it's a simple fix
Simplest DVD authoring program?
By paristideu in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2011, 11:08 -
A good dvd authoring program?
By t_jay17 in forum Authoring (DVD)Replies: 3Last Post: 31st Mar 2010, 21:50 -
Which dvd authoring program could I use...
By sagat93 in forum Authoring (DVD)Replies: 5Last Post: 14th Oct 2009, 21:43 -
which dvd-authoring program is better?
By siluet in forum Authoring (DVD)Replies: 9Last Post: 8th Oct 2008, 14:25 -
The Best DVD Authoring program
By Random490 in forum Authoring (DVD)Replies: 6Last Post: 12th Dec 2007, 04:10
