I have two already recorded dvds that i need to put on one disc(they're not movies). What programme do i need to do this and how do i do it , i tried nero, but it didnt work, or am i being dumb. I take it you need to save one to the hard drive then the other and write it as one disc? Nero only saved parts of the different dvds ( 9 seconds of one and 13 of the other). Any help would be appreciated.
You can do this with DVDshrink, just take a look at the guides here,
http://www.videohelp.com/guides.php?...or+List+Guides
I suggest starting with this one,
http://www.videohelp.com/guides.php?guideid=538#538
or this one,
http://www.videohelp.com/guides.php?guideid=513#513
see how you get on.
Thanx for the info, it says for a backup, is that a noraml disc that wil play on my dvd player, i want to put the two things on to 1 disc so they can be watched? Thanks again.
Yes, it will be a normal burned DVD disc that should play on most settop players.
In order to save the first disc to your harddrive, create a folder in MY DOCUMENTS (this is where "Shrink usually looks first) to save it in. Back in 'Shrink, after your first movie is loaded on the left, click on BACK UP; in that window, select as TARGET your "Harddrive." After doing that, find your folder to save it to, and then hit SAVE. FYI At the bottom of the BACK UP window, a little check box will appear saying you're making TS VIDEO files, etc. Leave that alone.
You initally save one movie to your harddrive, then you re-save it again with the 2nd disc in the drive (to a new folder). With the 2nd disc in your drive, you open "Shrink again, have 'Shrink open/read it. Then after it's loaded on the left side of the window, open the first movie on your harddrive (either OPEN FILES on the toolbar, or find it on the right side of Shrink under DVD BROWSE tab. It will be re-read again by 'Shrink and appear on the left side too. Then you're ready to back up both again to a 2nd folder.
try this guide http://www.dvdshrink.info/compilation.php
"(they're not movies)"
Am I missing something here?
Are they data files? That can be watched? Viewed.
Multiple DVDs on a Blu-Ray Disc
By rstrom2008 in forum Newbie / General discussionsReplies: 1Last Post: 10th Jan 2012, 06:34 -
Comnimng Authored DVDs To One Disc
By phantomengineer in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2011, 21:23 -
i nee a machine that will rip lots of dvds to hard disc
By steve1033 in forum Newbie / General discussionsReplies: 0Last Post: 30th Jul 2010, 07:56 -
Why do my DVDs become corrupted at the end of the disc?
By NBninja8 in forum MediaReplies: 16Last Post: 16th Nov 2008, 14:54 -
Can you finalize a previously written disc?
By c5vetman in forum MediaReplies: 8Last Post: 28th Mar 2008, 08:16
