I encoded the real player format to AVI format but it didn't work and has no sound too when I clicked the play button on ffmpegx before encode it. I am a newbie in ffmpegx and I have Mac Powerbook G4 so I am using ffmpegx for mac version. What should I do to convert the real player file to AVI or Mpeg format?Can someone here please kindly help me?Thank you very much in advance.
below is the history of the encoding process, I have to idea what should I do:
[NULL @ 0x4199e0]Unsupported video codec
Input #0, rm, from '/Users/joanna/Desktop/fantasticfour/fantastic01.rm':
Duration: 01:12:10.0, start: 0.000000, bitrate: 542 kb/s
Stream #0.0: Audio: 0x0000, 64 kb/s
Stream #0.1: Video: RV40, 480x360, 12.00 fps, 469 kb/s
Stream #0.2: Data: 0x0000
Codec type mismatch for mapping #0.0 -> #0.0
Only mencoder engine supports Real, so use "DivX mencoder". Also make sure you installed the stable Real libraries as linked from http://homepage.mac.com/majo4/download.html
Thanks, major, for your fast reply and assistance.
I already downloaded the stable Real libraries codec form the linked page. And I have already followed all the instructions there.
I also tried to use DIVX Mencoder this time, but still no avail.
What should I do?Sorry to bother you again but I really need your help, it's really meaningful to me. Thank you so much.
Below is the history of teh encoding process:
Encoding started on Tue Nov 22 16:59:41 PST 2005
MEncoder dev-CVS-050814-13:46-3.3 (C) 2000-2005 MPlayer Team
Mac OSX static build for ffmpegX
AltiVec found
CPU: PowerPC
success: format: 0 data: 0x0 - 0x1184497c
REAL file format detected.
Stream description: Audio Stream
Stream mimetype: audio/x-pn-realaudio
Stream description: Video Stream
Stream mimetype: video/x-pn-realvideo
Stream mimetype: logical-fileinfo
VIDEO: [04VR] 480x360 24bpp 30.000 fps 0.0 kbps ( 0.0 kbyte/s)
[V] filefmt:11 fourcc:0x30345652 size:480x360 fps:30.00 ftime:=0.0333
Opening audio decoder: [realaud] RealAudio decoder
Error: dlcompat: file "/Library/Application Support/ffmpegX/reallib/cook.so" not found
opening shared obj '/Library/Application Support/ffmpegX/reallib/cook.so'
Read the RealAudio section of the DOCS!
ADecoder init failed
opening shared obj '/Library/Application Support/ffmpegX/reallib/cook.so.6.0'
ADecoder preinit failed
Error: dlcompat: file "/Library/Application Support/ffmpegX/reallib/cook.so.6.0" not found
Decoder init failed, error code: 0x80040005
Cannot find codec for audio format 0x6B6F6F63.
d obj '/Library/Application Support/ffmpegX/reallib/cook.bundle/Contents/MacOS/cook'
Read DOCS/HTML/en/codecs.html!
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
Opening video filter: [scale w=480 h=256]
Error: dlcompat: file "/Library/Application Support/ffmpegX/reallib/drvc.so" not found
Opening video decoder: [realvid] RealVideo decoder
opening shared obj '/Library/Application Support/ffmpegX/reallib/drvc.so'
Read the RealVideo section of the DOCS!
VDecoder init failed
opening shared obj '/Library/Application Support/ffmpegX/reallib/drv4.so.6.0'
Error: dlcompat: file "/Library/Application Support/ffmpegX/reallib/drv4.so.6.0" not found
opening shared obj '/Library/Application Support/ffmpegX/reallib/drvc.bundle/Contents/MacOS/drvc'
Selected video codec: [rv40mac] vfm:realvid (Mac OS X RealPlayer 9 RV40 decoder)
Forcing output fourcc to 58564944 [XVID]
Writing AVI header...
ODML: Aspect information not (yet?) available or unspecified, not writing vprp header.
VDec: vo config request - 480 x 360 (preferred csp: Planar I420)
VDec: using Planar I420 as output csp (no 0)
Movie-Aspect is 1.33:1 - prescaling to correct movie aspect.
SwScaler: reducing / aligning filtersize 1 -> 1
SwScaler: reducing / aligning filtersize 2 -> 2
SwScaler: FAST_BILINEAR scaler, from Planar YV12 to Planar YV12 using AltiVec
videocodec: libavcodec (480x256 fourcc=58564944 [XVID])
I don't see any errors in video, what did you obtain here? perhaps no audio? (it seems the audio track is not recognized). Also check whether pressing PLAY actually plays the Real file.
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD)Replies: 80Last Post: 27th Apr 2009, 20:00 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15 -
how to make sure that your output format for autogk is either, avi, mpeg..
By sharmine in forum Newbie / General discussionsReplies: 1Last Post: 19th Sep 2007, 06:00
Statistics
Newest guides
Latest tool updates
New media comments
