    I used tmpgenc's "SuperVideo CD(NTSCFilm)" setting the only thing I changed was the video bitrate from the default to 918 and audio bitrate from 224(the default) to 128 because my player can't play overburned SVCDs. But 128 is still SVCD standard so why is VCDEasy autopadding my already standard SVCD?
    Here is the G-spot info from my file:
    --- File Information ---
    File Name: Family Guy - Stewie Griffin the Untold Story.mpg
    File Name (with full path): C:\shows\svcd\Family Guy - Stewie Griffin the Untold Story.mpg
    File Size (in bytes): 702,697,476
    --- Container Information ---
    Base Type (e.g "AVI"): MPEG (.MPG/.MPEG/.VOB)
    Subtype (e.g "OpenDML"):
    Interleave (in ms):
    Preload (in ms):
    Audio alignment("split across interleaves"):
    Total System Bitrate (kbps): 1064
    Bytes Missing (if any):
    Number of Audio Streams: 1
    --- Video Information ---
    Video Codec Type(e.g. "DIV3"): MPEG2_Video
    Video Codec Name(e.g. "DivX 3, Low-Motion"): MPEG-2
    Video Codec Status(e.g. "Codec Is Installed"): Codec(s) are Installed
    Duration (hh:mms): 01:28:20
    Frame Count: 158842
    Frame Width (pixels): 480
    Frame Height (pixels): 480
    Frame Aspect Ratio (e.g "1.3333"):
    Frame Aspect Ratio (e.g. "4:3"):
    Pixel Aspect Ratio ("SAR"):
    Display Aspect Ratio ("DAR"): 1.333
    Frames Per Second: ***ERROR***
    Video Bitrate (kbps): 918
    MPEG-4 ("MPEG-4" or ""):
    B-VOP ("B-VOP" or ""):
    QPel ("QPel" or ""):
    GMC ("GMC" or ""):
    H264 ("H264" or ""):
    MPEG-2 ("MPEG-2" or ""): MPEG-2
    Interlaced ("I/L" or ""): I/L
    Progressive ("Prog" or ""):
    Top Frame First ("TFF" or ""):
    Bottom Frame First ("BFF" or ""):
    3:2 Pulldown ("3:2" or ""): 3:2
    Picture-per-field ("PPF" or ""):
    - Aspect Ratio Related:
    Broadcast standard: "PAL" (else blank)
    Broadcast standard: "NTSC" (else blank) NTSC
    src:"VCD", "SVCD", "CVD", or "DVD (else blank): SVCD
    Instructions to convert to VCD, first part:
    Instructions to convert to VCD, second part:
    Instructions to convert to SVCD, first part: Resize to 481 x 481 ( w:[1/1] h:[1/1] )
    Instructions to convert to SVCD, second part: Trim 0 from l, 1 from r, for 480 x 480
    Instructions to convert to CVD, first part: Resize to 363 x 484 ( w:[3/4] h:[1/1] )
    Instructions to convert to CVD, second part: Trim 5 from l, 6 from r, Trim 2 from t/b for 352 x 480
    Instructions to convert to DVD, first part: Resize to 723 x 482 ( w:[3/2] h:[1/1] )
    Instructions to convert to DVD, second part: Trim 1 from l, 2 from r, Trim 1 from t/b for 720 x 480
    Instructions to convert to AVI, first part: Resize to 697 x 510 (Use +/- for other target sizes)
    Instructions to convert to AVI, second part: Crop off any non-picture areas, if req'd
    --- Audio Information ---
    MPEG Stream ID (e.g. "0xbd"): 0xc0
    MPEG VOB file Substream(e.g. "0x80"):
    Audio Codec (e.g. "AC3"): MPEG-1 Layer 2
    Audio Codec Status (e.g. "Codec Is Installed"): Codec(s) are Installed
    Audio Sample Rate (Hz): 44100
    Audio Bitrate(kbps): 128
    Audio Bitrate Type ("CBR" or "VBR"): CBR
    Audio Channel Count (e.g. "2" for stereo): 2
    I forgot, here is the VCDEasy log
    [Internal Xml Generation]
    Internally computed XML generated successfully: "C:\shows\svcd\videocd.xml"
    [VCDxBuild.exe]
    GNU VCDImager 0.7.12
    initializing libvcd 0.7.12 [cygwin/i686]
    this is the UNSTABLE development branch!
    use only if you know what you are doing
    see http://www.hvrlab.org/~hvr/vcdimager/ for more information
    changed volume number to 1
    changed volume count to 1
    changed restriction number to 0
    changing 'next volume use sequence 2' to 0
    changing 'next volume use lid 2' to 0
    changed volume label to `SUPER_VIDEOCD'
    changed publisher id to `VCDEASY_V1152'
    changing 'update scan offsets' to 1
    changing 'relaxed aps' to 0
    adding pbc (Selection-000/2)
    adding pbc (Selection-001/2)
    adding pbc (Selection-end/3)
    adding segment #0, C:\shows\svcd\vlcsnap-859163.mpg
    pts start offset 1.714333 (max pts = 1.714333)
    playing time 0.000000
    mpeg stream contained no scan information (user) data
    scanning mpeg segment item #0 for scanpoints...
    already scanned... not rescanning
    SPI length is 45 sector(s), allocated 1 segment(s)
    sequence count 1
    adding sequence #0, C:\shows\svcd\Family Guy - Stewie Griffin the Untold Story.mpg
    mpeg stream will be padded on the fly -- hope that's ok for you!
    Next time, let VCDEasy analyse the MPEG files to have this warning before...
    strange (possibly non-compliant) user_data seen... (not a problem, usually a sign of TMPGEnc)
    APS' pts seems out of order (actual pts 72.651633, last seen pts 72.735044) -- ignoring this aps
    APS' pts seems out of order (actual pts 143.138711, last seen pts 143.222133) -- ignoring this aps
    APS' pts seems out of order (actual pts 195.390911, last seen pts 195.440967) -- ignoring this aps
    APS' pts seems out of order (actual pts 1736.814133, last seen pts 1736.847500) -- ignoring this aps
    APS' pts seems out of order (actual pts 2045.372378, last seen pts 2045.405744) -- ignoring this aps
    APS' pts seems out of order (actual pts 2292.986411, last seen pts 2293.036467) -- ignoring this aps
    APS' pts seems out of order (actual pts 2593.953744, last seen pts 2594.003800) -- ignoring this aps
    APS' pts seems out of order (actual pts 2931.541000, last seen pts 2931.591044) -- ignoring this aps
    APS' pts seems out of order (actual pts 3770.879500, last seen pts 3770.929544) -- ignoring this aps
    APS' pts seems out of order (actual pts 3956.865300, last seen pts 3956.948711) -- ignoring this aps
    APS' pts seems out of order (actual pts 4179.454333, last seen pts 4179.537744) -- ignoring this aps
    APS' pts seems out of order (actual pts 4205.029878, last seen pts 4205.063244) -- ignoring this aps
    APS' pts seems out of order (actual pts 4372.563911, last seen pts 4372.613967) -- ignoring this aps
    APS' pts seems out of order (actual pts 4776.851133, last seen pts 4776.934544) -- ignoring this aps
    pts start offset 1.080133 (max pts = 5300.254011)
    playing time 5299.173878
    autopadding requires to insert additional 94699188 zero bytes into MPEG stream (due to 343113 unaligned packets of 343114 total)
    scanning mpeg sequence item #0 for scanpoints...
    pbc: psd size 104 (extended psd 0)
    iso9660: highest alloced sector is 390 (using 391 as isosize)
    generated image (343805 sectors [76:24.05]) may not fit on 74min CDRs (333000 sectors)
    OGT streams available: 0 0 0 0
    writing track 1 (ISO9660)...
    setting EOR for SeqEnd at packet# 43 ('Segment-0001')
    'update scan offsets' option enabled for the following tracks!
    writing track 2, MPEG2, NTSC 2/3 D-1 (480x480/30fps), audio[0]: l2/44.1kHz/128kbps/stereo ...
    mpeg: some marker is not set...
    non-MPEG1 audio stream header seen
    MPEG packet statistics: 301077 video, 42037 audio, 0 zero, 0 ogt, 0 unknown
    writting post-gap ('leadout pregap')...
    finished ok, image created with 343805 sectors [76:24.05]
  1. Help: Autopadding error message on mpeg files
    By kukm66 in forum Authoring (VCD/SVCD)
    Last Post: 8th Feb 2003, 10:11
  2. This MPEG file requires autopadding
    By Bizuser in forum VCDEasy General
    Last Post: 29th Jan 2003, 09:07
  3. Autopadding?
    By spleen in forum Newbie / General discussions
    Last Post: 23rd Jan 2003, 08:23
  4. Autopadding error with TMPGENC
    By ghost00 in forum Newbie / General discussions
    Last Post: 26th Dec 2002, 20:11
  5. MPEG file requires autopadding
    By TElk in forum VCDEasy General
    Last Post: 16th Dec 2002, 23:47
About   Advertise   Forum   RSS Feeds   Statistics   Tools
