Hi Major
I was playing around with Sorenson Squeeze the other day and I noticed 2 features that I think would be great to have in FFmpegX:
1. When entering the target framerate, you could select "2:1" or "3:1" in addition to just typing the number.
That way you can make a preset that changes the framerate to 1/2 or 1/3 of the original, regardless of the original framerate. As it is now, you have to create a preset for each variation.
2. When entering the target size, you could set maximum width and height and tick a box called "maintain aspect ratio".
This would reduce the screensize to the maximum width or height possible without changing the aspect ratio. So if for example your target was a size of 320x208 pixels, your would get either 320 pixels wide or 208 pixels high (depending on the aspect ratio), ensuring that you utilize the screen space optimal without changing the aspect ratio.
Again, this would allow you to make 1 preset that would cope with a lot of different input formats, changing them all to fit a certain target format.
cheers
Peter
Results 1 to 1 of 1
Thread: Suggestion for new features
Multicore suggestion?
By pardu in forum LinuxReplies: 18Last Post: 27th Jun 2010, 19:18 -
what features do you want Windows 8 to have?
By deadrats in forum ComputerReplies: 3Last Post: 4th Feb 2010, 19:11 -
Converter with these 2 features...
By marioval in forum Video ConversionReplies: 4Last Post: 6th Nov 2009, 08:03 -
New Forum Features
By vhelp in forum FeedbackReplies: 2Last Post: 30th Mar 2008, 09:49 -
Features
By Jedi_Knight in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 29th May 2007, 18:29
