VideoHelp.com Forum
  1. For quite some time now been backing up me DVDs using the CloneDVD/Any DVD combination. Worked flawlessly onmost video media and copies were playable on all my non-pc dvd players. Now this is history, whatever copies I mak can onlybe played on pc dvd-drives, the only stand-alone dvd player that still reads them is my Kiss 500. Any clues?
    if i'm wrong i'm right
    Have you changed media (brand) ?
    If not, get one of you old disks and get the media code (DVD Info Pro of similar can show you this), and compare it to the media code of the new disks that don't work. Sometimes vendors change manufacturers without changing brands, and use lower quality disks.
    If this is universal (i.e. affecting players other than yours) then media is the likely culprit. If it only affects your players, perhaps they need a clean or are just getting old.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  3. Do you put labels on your DVD's? If so do search on that topic.
    DVD players have a limited lifespan, lasers die rather early, sometimes as fast as 6-12 months. The first things that quit reading are burned discs.
    If the KISS and computer can player them, then that eliminates the discs, most likely.
    Labels could be a problem, as well as low quality media that are harder to read.
    What brand/ID of media are you using?
    Read www.nomorecoasters.com
    Have you changed any of the settings on your progs lately?
    Are you burning discs as dcd video or dvd data discs?
    I know that KISS DVD players are some of the only players that will play DivX avi files. Where the movies that you burned to DVD in DivX format? That would explain why you can't play them in any other DVD player...
  7. Member Capt.Video's Avatar
    Ive had similar happen, ended up being the DVD recorder, it was dieing. I replaced it with an NEC from newegg.com and have had ZERO problems, even using imation DVD media!!
    Anyway, sounds like its your recorder trying to fritz on ya.
    HTH,
    Andrew
    I have been into computers since 1980. Ive been tinkering with DV in one flavor or another since 1990.
  1. Replies: 0
    Last Post: 30th Jan 2011, 14:57
  2. Chapters no longer work after adding audio to DVD.
    By Nagashi in forum DVD Ripping
    Last Post: 25th Jul 2010, 17:27
  3. multiAVCHD - subtitles no longer work
    By bobo343 in forum Newbie / General discussions
    Last Post: 8th Apr 2010, 08:58
  4. SVCD2DVD used to work, no longer
    By gddeluca in forum SVCD2DVD & VOB2MPG
    Last Post: 23rd Sep 2009, 10:45
  5. DVD Players no longer work on tv?? Any ideas?
    By -mm- in forum DVD & Blu-ray Players
    Last Post: 15th Nov 2008, 19:13
