Then I encode in TMPGEnc (divx to ntsc vcd mpeg) the time remaing starts out with 3 hours remaining then all of a sudden jumps to 69+ hours remaining. I'm using a ntsc vcd template. high quality.
What's your CPU and want's the runtime of the source. Does the preview screen show the whole time or go blank.
I'm running a Sony vaio with 450 mhz
256 ram pentium III
the screen is previewing the movie I ran a couple of tests with short encodes and it seems that the mpegs are gigantic. How will I burn them on a single cd? Do I have to make a image cue and bin to burn onto cd?
jcee28,
try this out for size.
* re-encode again, but this time, change your NQ (normal quality) since it's
much faster. But what we want to try and see is if you get the same 69 hours
or lesser. Maybe 22 hours, but this will help you narrow down the problem.
* Next, try setting your [x] Source, under Advance tab and (dbl-click it) and
set a 1000 frame or (10,000 - to get a better timeing) and, again, set to
NQ and see how long it says.
Sometimes, it pays to do some detective work.
- vhelp
Thanks I guess I'm getting into the technicality of this stuff. I narrowed it down to 20 and now around 7 hours. I could deal with that. I guess it's trail and error with a lot of fiddling around with settings. Thanks again!
I'm on to learning menu and chapter making I'll let you know if I run into any problems.
Jay
MeGUI encoding starting over, taking many hours
By Poonaroon in forum Video ConversionReplies: 1Last Post: 9th Apr 2012, 07:58 -
web cam directly to laptop dvd burner in real time? hours
By troutdavid in forum Newbie / General discussionsReplies: 1Last Post: 17th Jun 2009, 05:48 -
It took 11 hours with TMPGEnc 3 to make a 2 hour video folder
By nhbfan12345 in forum Authoring (DVD)Replies: 3Last Post: 9th Dec 2008, 14:18 -
DVR650 Pioneer DVD recorder shows zero hours remaining
By jackdup in forum DVD & Blu-ray RecordersReplies: 4Last Post: 17th May 2008, 16:24 -
Burning time taking 2 hours???
By Its Pink Ninja in forum Newbie / General discussionsReplies: 8Last Post: 3rd Jun 2007, 16:55
