I have video file (mpg) of resolution of 176X 144 . If I am making a vcd with this file the picture comes very poor on tv. So I want to improve the resolution of the video to 512 X 384. Is there any way to improve the quality or video size? If so, what tool should I use. Kindly help.
Also is there any tool to find the resolution and birate for a video file?
Thiyagu
Results 1 to 9 of 9
Nope. Increasing the resolution of a video will degrade it regardless of the situation. If you increased the resolution and played it back on your monitor full screen the original would look better that the higher resolution one.
The quality of the video will never be better than what you start with. While there are some tools that will permit you to process the footage (1. expand pixel size, 2. blur/degrade the image, 3. unsharp mask it), you can readily see that this will just make it a mess (albeit larger).
I believe there's "mpeg info" (or something similarly named) that will provide the details of the mpeg file. -
I have to take issue with this statement, otherwise why bother with all those avisynth and virtualdub filters ? The first rule of video is first do no harm. The output should not be worse than the source. The second is try to improve on the source. Not always possible, granted (hence rule one).The quality of the video will never be better than what you start with
In this case you may well be able to improve the quality of the video, however resizing it to double it's current (low) resolution isn't going to do that.
The latest version of g-spot can handle mpeg files, as well as most other formats. Find it in the tools section.Read my blog here.
Look at it this way ....Originally Posted by thiyagups
You have 25344 pixels of information in your source file. You want 196608 pixels in your putput file, meaning the computer has to figure out / embellish / guesstimate the contents of 171264 pixels, or 87% of your pocture. Pure and simply, it ain't gonna happen. Let me rephrase that - it can happen, but it won't be pretty. TBH, even quadrupling the frame size to VCD-compliant 352 x 288 will be a task in itself to keep watchable, and then you've got the DVD Player doing a resize to full-screen on playback. I conclude with - it ain't gonna happen.
For educational purposes, knock yourself out. But I wouldn't waste your time if I were you.
GSpot. The latest Beta (2.52) supports MPEG video.Originally Posted by thiyagupsIf in doubt, Google it. -
I'm sorry that you're rationalizing how you waste your time.Originally Posted by guns1inger
Video can be improved, don't let anybody tell you differently, but that's generally because you are starting with analog video and plan to use a battery of analog processing hardware and filters.
On the other hand, anything that starts out digital, and is LOW RESOLUTION, and is poor quality, is pretty much damaged forever. That's basically what we have here. You can try a few things to make it less ugly, but not by too much.Want my help? Ask here! (not via PM!)
How to increase resolution in GUI for dvdauthor, please?
By Centauri39 in forum Authoring (DVD)Replies: 21Last Post: 12th Mar 2021, 18:49 -
Encode video with different luminance resolution and video resolution
By kylix999 in forum Video ConversionReplies: 14Last Post: 6th Jun 2012, 08:57 -
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 07:36 -
how do i increase my video resolution to 720p with my 680p?
By lucchini in forum Newbie / General discussionsReplies: 1Last Post: 30th May 2010, 17:14 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 02:57
