VideoHelp.com Forum
  1. I've been trying to creat a simple dvd of the first season of a show. I had problems with Diko so I tried using Divxtodvd and everything worked fine EXCEPT that i want to add menu's. I tried loading the files up in TMPGenc author but it says there is an error. I looked at the common problems with TMPGENC and nothing seems to work. Normally I would just use Nerovision and complete the job quickly BUT it doesn't support multiple subtitles (whcih I want to include). What can I do to add a menu now that I have the videots folder with all the files created?
    To recap all I want is:
    1. A simple menu
    2. 2 subtitles tracks for each episode (7 episodes in all)
    Is there anything that can help me get this done without a problem?
  2. VH Veteran jimmalenko's Avatar
    TMPGEnc DVD Author doesn't support ANY subtitles AT ALL, so it's not going to be any help.
    1. A simple menu
    DVD-lab.
    If in doubt, Google it.
    dvdauthorgui can do this if its a simple project you are trying to create .
    Have a spin around the guides section , I use it to create my scratch projects from input files , then move onto pcgedit for more advanced features such as command editing .
  4. Serene Savage Shadowmistress's Avatar
    Dvdlab can do everything without the need for other software. Have a look at this guide: Complete newbie beginners guide to dvdlab and this guide How to add subtitles to a dvd.
    In the second guide you can skip steps 1 and 3. Just step 2 deals with adding subs and all you'd need to do is repeat it for the next sub slot which will appear after you've entered the first. Dvdlab supports up to 8 subtitle streams.
  1. DVD: Can You Add .SRT To A VIDEO_TS Folder/Files?
    By SetoTitan in forum Subtitle
    Last Post: 4th Mar 2011, 19:04
  2. An idiot and a video_ts folder...
    By CitizenErased in forum Newbie / General discussions
    Last Post: 24th Jan 2011, 16:00
  3. Convert VIDEO_TS folder into video & audio ES files?
    By boxingfanmike in forum Video Conversion
    Last Post: 22nd Oct 2009, 13:09
  4. No Video_TS Folder..
    By NatalieR in forum ffmpegX general discussion
    Last Post: 5th Feb 2008, 10:53
  5. Make menu for "VIDEO_TS" folder (files inside it)...
    By Chana1 in forum Authoring (DVD)
    Last Post: 24th Jul 2007, 08:29
