VideoHelp.com Forum
    If i play an mp3 and turn up the volume to full and put the speaker to my hear i can just make out the music but there is also a terrible humming sound.
    I have found the culprit it is my new external hard drive,as soon as i unplug it my speakers work properly again!
    Any ideas on what could be causing this?
  2. Member Xylob the Destroyer's Avatar
    you haven't provided enough information regarding your PC's set-up....
    is your sound card internal? external? on-board?
    how is your external HD connected?
    what OS?
    just a blind guess, but it sounds like some kind of IRQ conflict could be the issue?
    "To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
    "Megalomaniacal, and harder than the rest!"
    Sorry mate......Here goes...
    XP SP2
    Internal creative soundblaster live sound card.
    Ext hard drive connected via usb port..
  4. Member Xylob the Destroyer's Avatar
    is your USB port an add-in card or on-board?
    either way, this is a fairly odd "conflict"....
    have you updated all of your drivers?
    does your audio take a shit when you use other USB devices?
  5. Mod Neophyte Super Moderator redwudz's Avatar
    If not a IRQ problem, maybe a overloaded power supply? Unplug a few devices, drives or cards and try again. (Do the unplugging when the power is off and disconnected. )
    I have 2 usb's on front and 4 on the back(not to sure whether USB port an add-in card or on-board)will have to have a look inside...
    I think it is a bit of both at a guess.
    The audio only goes once i plug in the ext hard drive but is ok at all other times..
  7. Member Xylob the Destroyer's Avatar
    set it on fire and do the wacky-tiki dance of deadly death around it while wearing nothing but tighty-whiteys on your head and some ceremonial body paint.
    redwudz makes a very good point about the power issue -- I didn't even think of this because I have an ungodly monsterous power supply, so it's never really an issue for me. if this is on of those pre-built package deal PC's (dell, GateWay, etc...) you may have a relatively underpowered PS.
  1. Replies: 1
    Last Post: 18th Jan 2012, 22:00
  2. Replies: 2
    Last Post: 11th Aug 2011, 19:38
  3. Replies: 32
    Last Post: 28th Jun 2011, 15:21
  4. problem with external hard drive
    By ttheb1 in forum Newbie / General discussions
    Last Post: 17th Jul 2010, 01:37
  5. help with connecting external drive to Cyclone HD player
    By JamesUK in forum Media Center PC / MediaCenters
    Last Post: 25th Sep 2009, 03:20
