VideoHelp.com Forum
    I am new in this forum, and I just installed ffmpegX 0.0.9k... or tried to.
    It looks like the binaries and mpeg2enc have been installed succesfully, but it gives me an error:
    The installation was not successful ##sudo: gnutar: command not found
    After reading a lot of posts in this forum trying to find an useful advice, I changed the binaries and mpeg2enc to the Application Support folder, taking them from the Applications one. But still the same error is appearing.
    I think this observation might be important: in the "ffmpegX components self-installer" box four items remain in red, and signaled:
    libogg/libvorbis/DLCompat
    libmp3lame
    gocr/subtitles
    yuvtools/vcdimager
    but I do not know where i must take them from, and where must be placed... I don't know what to do with them, you know.
    I would be grateful if anyone help me
    So rare is my case that no one knows what is happening to me?
    mitraxxi
  3. The installation instructions at http://homepage.mac.com/major4/download.html say "If you get an error message "missing gnutar", then first install version 0.0.9h then switch to version 0.0.9k."
    I am afraid I did not see that link.
    Have I to unistall 0.0.9k first?
    Well, Major, it looks as the installation was ok at last I thank you very much!
    Indeed, there are no errors but, after encoding, the new converted file disappeared: no where I tried to send it (the same folder than the the former one), and nowhere in the whole computer.
    I tried to convert an rm (Real Audio) file to mp3 (the ffmpegX put avi to it), and the search engine of the Mac found anything ended neither mp3 nor avi and, I repeat, it gave no error.
    I tried to find the guides, but the only mentions to this conversion refered to video and, worse, those explanations were so much technical that I was unble to aply it to an audio conversion. I am really sorry because I am not a specialised person.
  6. Unfortunately, audio only-conversion from rm to mp3 is not supported for now.
  1. ffmpegx.com installation
    By a.fritz in forum Video Conversion
    Last Post: 16th Jan 2011, 23:38
  2. No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
    By koberulz in forum Newbie / General discussions
    Last Post: 24th Jan 2010, 04:48
  3. Bad motherboard or bad CPU?
    By videohalp in forum Computer
    Last Post: 9th Jul 2008, 10:07
  4. Installation error -
    By ruggerjvd in forum ffmpegX bugs and suggestions
    Last Post: 12th Nov 2007, 09:06
  5. Bad encoding? Bad installation
    By lo-q in forum ffmpegX bugs and suggestions
    Last Post: 22nd Sep 2007, 19:45
