VideoHelp.com Forum
  1. I have two files that I would like to join but it doesn't seem to be going well and I have never seen this before. The properties of the two files are as follows.
    File 01
    File 02
    When they are joined I get a total time of something like 2hrs and 40 minutes which if you look at the lengths makes no snese. I'm using VirtualDub 1.6.11.
    Any Ideas why this is happening?
    If the second clip was added twice then it would = 2 hours 40 minutes.
    Could this be the problem?
    Chas
    Probably it is autoloading the second segment, then you are manually loading it again. Result as above is the second part twice. If files are named correctly VDub will autoload them.
  1. corrupt .mts file (incorrect length)
    By sandergoorden in forum Video Conversion
    Last Post: 27th Mar 2012, 08:45
  2. Replies: 32
    Last Post: 5th Feb 2012, 15:17
  3. Joined VOB files... but length remains splitted?
    By Metallo in forum Authoring (DVD)
    Last Post: 7th Nov 2009, 03:44
  4. Video file time length is incorrect after converting to M2TS
    By Alterego in forum Video Conversion
    Last Post: 18th Oct 2008, 10:54
  5. Replies: 8
    Last Post: 26th Feb 2008, 17:29
