VideoHelp.com Forum
Results 1 to 19 of 19
  1. Member pharries's Avatar
    I love my Canopus ADVC-300
    Only problem is I am not getting the most out of it
    Can any one explain the following:-
    1) 2D vs 3D noise reduction?
    2) The effect of the Y and C filter settings for each?
    3) When to Use Black expoansion, white expansion andWhite Step?
    4) Video AGC, I adjust this a lot, it certainly helps. Any quidelines?
    I am obviously going to be MPEG compressing subsequently so bear that in mind. Am I wasting my time with some of these settings?
    (I use Canopus Procoder Express)
    A guide for this would I am sure be appreciated!
    Paul
  2. Member Wile_E's Avatar
    I have ADVC-300 too, but I think the Picture Controller software sucks big time. It is really a joke, and Canopus never has updated it. But to answer your questions...
    1) 3D NR is usually better, as it uses previous/next frames to calculate noise reduction for the frames. 2D just blurs the picture of all frames. Put 3D NR on low setting. Anything higher may cause artifacts or ghosting in some colors.
    2) Y Brightness C Chroma(Color). I believe these settings only affect the composite input. S-Video is already seperated.
    3 & 4) I would leave these all at defaults, unless you have a waveform display, to guide you. If you brighten/darken too much, your video could get out of spec. Sony Vegas has a waveform display to show the IRE levels, and you want them between 0-100 IRE (16-235). The default for video AGC on my ADVC-300, seems a little too bright. Whites go up to about 105 IRE. So I usually set this control to manual, and adjust it down.
    Had anyone found a setting for the TBC?
    I leave all settings to default, besides audio.
    Any tweaking with the video filtering resulted in bad captures (no detail, artefacts and so on).
    ADVC-300 is all marketing, and little follow through. Most users I've seen/met/read/heard report more flaws if they try to filter. The TBC is also questionable on whether it's truly a TBC, and not some sort of pseudo/virtual/partial TBC-like device. Those sort of things are usually just on/off, there are no "settings" to be had on them.
  5. Member pharries's Avatar
    Very interesting
    I have been capturing old U-matic tapes and have noticed that setting the 2D y is either Low or medium is best
    I also have noticed the AGC is a little too high and turn it down just a little.
  6. Member pharries's Avatar
    Wile_E
    I am getting an oscilloscope. Any guides on how to use it to opttomize the picture?
  7. Member edDV's Avatar
    Originally Posted by pharries
    Wile_E
    What you need is a waveform monitor, and these need to be in calibration.
    http://search.ebay.com/waveform-moni...opZ3QQsbrsrtZl
    http://www.kiva.org/about
  8. Member edDV's Avatar
    The manual is not informative and there are no published app notes.
  9. Member pharries's Avatar
    This is interesting
    Has anyone tested the TBC on the unit
    I just sold my TBC this week on Ebay thinking I had one in the canopus!
  10. Member edDV's Avatar
    This is interesting
    Are you seeing any timebase correction?
    It seems to have only automatic modes. Reading the manual, I can't tell if TBC is always in the loop or just turned on when composite or S-Video is connected. In fact, I see no mention of TBC in the manual.
    Maybe an owner should call Canopus support.
    I called Canopus support:nothing is known about the TBC (I didn't find anything in the manual too).
  12. Member pharries's Avatar
    I emailed them asking the same questions as above and invited them to join this discussion as well.
    Hope they do
  13. Member pharries's Avatar
    I got this reply from canopus today
    Let me start by answering your questions:
    01. The 2D Noise reduction blurs the image so that the sharp noise is not very noticeable.
    The 3D Noise reduction compares the previous and the next frames for differences, and then removes the noise.
    02. The Y and C settings gets a little complicated. Y signal is the Luminance signal (The brightness of the video), and the C signal is the chrominance signal (Color).
    03. You use the Black Expansion when the black of the video does not look black. Sometimes, on old videos, they look a little gray. And the same thing is on the White adjustments.
    04. The AGC is used to gain some brightness on the video so that it looks comfortable to the eyes. It is also the circuitry that automatically adjusts the gain level providing optimum signal output and preventing potentially damaging circuit overload. AGC circuits are used in cameras and recording devices, and other video devices to maintain proper signal levels without requiring an operator to manually monitor controls.
    05. The TBC function of the box is only a Line TBC. It can eliminate some horizontal noise lines on the old video.
    The rule of thumb is to connect a TV to the output of the ADVC-300, and view the picture from your TV, and not the VGA monitor while adjusting. The default settings should work for most videos, but you need to know what to adjust before you do it. This ADVC-300 packs a lot of professional features on a consumer box, and therefore, the functions tend to confuse people.
  14. Member edDV's Avatar
    Did you get a name there? I think they should be offering a better explanation of the features for a $450-550 consumer product. Private message the name to me.
  15. Member pharries's Avatar
    PM'd the name to you.
    I felt the answer only told me what I knew already, no real guidance.
    frankly I have gone this week from being a devotee of Canopus (I have bought 6 of their products) to the point that I will think twice before spending any more money there,
    Compare their response with the likes of the creators of DVDlab! My impression is that either the employees are unhappy, there are problems with the company or they have gotten too big I guess!
    I have had much better responses from Msoft!!!!!!
  16. Member edDV's Avatar
    Their other products seem to be well supported. The ADVC-300 has never been very well documented, especially the TBC feature. I'll see what I can find out.
  17. Member Wile_E's Avatar
    04. AGC circuits are used in cameras and recording devices, and other video devices to b[]maintain proper signal levels[/b] without requiring an operator to manually monitor controls.
    "Maintain proper signal levels." Yeah right. Then why does AGC boost the level to over 100IRE? When having everything on default, my videos go up to about 105-107 IRE. And about the black expansion. Black on NTSC is supposed to look dark grey, not total black! It is quite obvious that Canopus is not trying to maintain a pure signal. They have defaults set up to "enhance" the signal. I suppose you can also this "problem" another way...enhance it so it looks similar to current digital formats. So it looks better for the grandkids in the future, when they all have super-high resolution displays. Otherwise grandkids will wonder why black looks grey.
  18. Member pharries's Avatar
    I bought a waveeform monitor on Ebay
    http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN%3AIT&rd=1
    Any advice on how to use it with the Canopus unit?
  19. Member pharries's Avatar
    How do you guys measure IRE anyway?
  1. Capturing with canopus advc 300
    By blacksheepdownunder in forum Newbie / General discussions
    Last Post: 19th Jul 2010, 08:20
  2. canopus advc 300 macbook pro
    By petoo2 in forum Video Conversion
    Last Post: 9th Dec 2009, 19:29
  3. Replies: 0
    Last Post: 1st Apr 2009, 12:36
  4. Need help in choosing a VCR to be used with a Canopus ADVC-300
    By teslaprofile in forum Newbie / General discussions
    Last Post: 10th Jan 2009, 22:31
  5. Canopus ADVC 300: best settings / tweaks ?
    By fabweb in forum Capturing
    Last Post: 12th Sep 2007, 06:34
