VideoHelp.com Forum
    I've searched quite a bit for noise filters (to remove noise from video), and I haven't found any for Vegas 5, or for Premiere 6.5 (with the exception that I found a link for a mainconcept plugin, except it's only in japanese. It seems the only one I have found is for TMPGEnc. Does anyone know how well this works, or if there are others. I know I won't get it all cleaned up, but every little bit helps...
    Rob
  2. Member ricky d's Avatar
    As far as software
    Vegas 5 has a noise gate built into it - Under Audio FX.. I use Adobe Audition cause it works great, and practically does it for you (with the default settings) tooks seconds to figure out.
    Lordsmurf wrote a good tutorial on using soundforge...
  3. Member FulciLives's Avatar
    There are "video noise" filters for VirtualDub and AviSynth.
    In fact one of the best is Convolution3D for AviSynth.
    This might help ---> CLICK HERE
    Hope this helps.
    - John "FulciLives" Coleman
    I'll give that a go this coming weekend. Thanks...
    Rob
    TMPGEnc works well.
  1. please list the virtualdub filters to remove vhs tape video noise
    By perfection in forum Newbie / General discussions
    Last Post: 14th Aug 2011, 11:02
  2. Help with avisynth filters, removing grain, dust or spatial noise
    By greyfalcon in forum Newbie / General discussions
    Last Post: 15th Mar 2010, 10:08
  3. Replies: 10
    Last Post: 11th Jan 2010, 00:57
  4. Replies: 8
    Last Post: 7th Jan 2010, 23:49
  5. Static/Dynamic Noise Reduction Virtualdub Filters
    By nutty88 in forum Restoration
    Last Post: 28th Feb 2008, 09:53
