VideoHelp.com Forum
    I have some short movie files of different types and have put them all onto one disc in Nero which burnt them as Data Discs. I couldn't burn them as VCDs as not all of the movie files are the right file types.
    On my PC they play fine in my DVD drive and CD Rom drive, but will that be the case on all PCs?? I want to copy and send these to some people, but am not sure if they will play OK.
    Also, are divx files OK to be burned as VCDs??
  2. Member edDV's Avatar
    Mostly NO for DVD players. Computers will play files based on which players, decoders and CODECs are installed.
    Study your DVD player specs for exceptions
    http://www.videohelp.com/dvd
    http://www.videohelp.com/vcd
    http://www.kiva.org/about
  3. Member canadateck's Avatar
    Yes if the person has a DVD-rom they will play as long as they have the right "Codec". I wouldnt worry about it.
  4. Member canadateck's Avatar
    What edDV said,he made an Edit to his Post. Before I posted..
  5. Member edDV's Avatar
    No problem
    Thanks for the replies guys. I think I'll just send them out then and tell them where to get the DivX codec.
  1. Replies: 51
    Last Post: 9th Jun 2010, 18:04
  2. Replies: 12
    Last Post: 5th Jun 2009, 10:53
  3. All Drives Not Recognizing Discs
    By Celcius in forum DVD & Blu-ray Writers
    Last Post: 31st Jul 2008, 15:33
  4. Do newer drives rip dual layer discs any faster?
    By Sephiroth666 in forum DVD & Blu-ray Writers
    Last Post: 21st Feb 2008, 09:40
  5. DVD drives won't recognize any discs
    By TIBGustaf in forum DVD & Blu-ray Writers
    Last Post: 3rd Jul 2007, 07:29
