VideoHelp.com Forum
Thread: Lightscribe
    What's the difference between Lightscribe DVD+/-R Media, and normal printable media?
    Can only lightscribe discs be used for printing in lightscribe drives? Or are normal printable discs compatible too?
    Thanks,
    Tony
  2. Member Shocker Milwaukee's Avatar
    Q: What's the difference between Lightscribe DVD+/-R Media, and normal printable media?
    A: Only lightscribe discs be used for printing in lightscribe drives. Normal printable media is designed for use with inkjet printers.
    If God had intended us not to masturbate he would've made our arms shorter.
    George Carlin
  3. Greetings Supreme2k's Avatar
    Yes.
  4. Can only lightscribe discs be used for printing in lightscribe drives ...Yes
    Or are normal printable discs compatible too? Yes and NO
    CAn be burned as normal BUT will NOT have lightscribe surface...they can be printed on using epson r200 or canon ip3000 or your own John Bull stencil set or even one of those dymo labelling gagdys but those labels are a bit thick, but you can get new ones that print really nice thin labels but they arent really used for labelling DVD or cdr tho I think its not a bad idea as they would not have the balance issues associated with full disk stick on labels..and dont overlook flashwrite(?) which is a new thing from the thingy companies which is exactly like lightscribe only it works at full burner speed eg 6-10 mins per disc and they hope the media will not be over priced, plus I think you can get two burned colors and the surface color... ahh the caffeine is wearing off now...
    The electronic components of the power part adopted a lot of Rubycons.
  1. Lightscribe Tips
    By jsmithepa in forum Media
    Last Post: 13th Aug 2010, 12:41
  2. are there dvd-r dl lightscribe?
    By m-man in forum Newbie / General discussions
    Last Post: 8th Sep 2009, 21:31
  3. Lightscribe worth it?
    By newworldman in forum DVD & Blu-ray Writers
    Last Post: 19th Aug 2009, 18:40
  4. lightscribe Printing
    By baqar in forum Media
    Last Post: 29th Feb 2008, 13:24
  5. Lightscribe
    By ridgerunrbunny in forum Linux
    Last Post: 4th Dec 2007, 14:48
