VideoHelp.com Forum
    I have a Samsung LCD TV 40" (1366x768) with HDMI that permit high definition trasmission (720p and 1080i). I have a Denon 1920 that upscales photos via HDMI at 1080i but the real definition viewed it's similar to the PAL system (576 lines).
    I want to know if someone has a dvd player that uses HDMI connection to view high definition photos at maximum level possible by the TV.
    Thank you
    Bye
  2. Member ebenton's Avatar
    A line from www.hometheaterstore.com, which sells Denon 1920 players, reads, 'It can upgrade or "upconvert" DVD video signals to near-High-Definition images' Notice the words "near-High-Definition". Just because a signal is coming out of an HDMI connector, does not necessarily mean that it is HD. In this case, it could be a signal of any resolution, wrapped in a 1080i signal. A tool-tip box about HDMI from this same website reads, "supports standard, enhanced or high-definition video".
  3. Member Krispy Kritter's Avatar
    Are you sure the images are in "high definition"?
    Google is your Friend
  4. Member edDV's Avatar
    Thank you
    Bye
    Normal DVD is 720x576. That player only upscales from 720x576 source material including photos. Upscaling doesn't add resolution. Nowhere does it say it accepts or outputs high resolution photos.
    You could run a 1280x720p slideshow from your computer, or wait for a HD DVD player. Some company would be smart to build a HDTV photo server that works as a wireless WIFI network device.
    http://www.kiva.org/about
  1. High definition conversion
    By kypreo in forum Video Conversion
    Last Post: 21st Mar 2010, 22:15
  2. Need help with HDMI, DVI-HDMI and "high definition audio device"
    By uart in forum Newbie / General discussions
    Last Post: 16th Mar 2010, 00:15
  3. Old films to high definition?
    By therock003 in forum Restoration
    Last Post: 20th Mar 2009, 13:05
  4. High Definition on DVD
    By Dem Pyros in forum Authoring (Blu-ray)
    Last Post: 2nd Sep 2008, 08:48
  5. video 8 to high definition
    By devdev in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 10th Jan 2008, 13:31
