VideoHelp.com Forum
Thread: movie length ?
    what's the best way to check the movie length people ? i need the exact time of the movie to config the codec.
    can we trust this ?
    thanks people
    Hi vgt,
    If you are familar with GraphEdit you can render your file without clocks (to be as fast as possible) and after that take a look at Video Renderer Property page. It will count all the video frames.
  3. VH Veteran jimmalenko's Avatar
    Being that your source is a DVD or MPEG-2 (hence your use of DVD2AVI or one of its later predecessors to frameserve via a D2V file), the IFO will tell you the exact running time. I'd open the IFO in IFOEdit and grab it from there. Failing that, if by chance you have one big VOB, you could use the latest GSpot Beta (2.52) an it will tell you the number of frames, the framerate and the total running time.
    If in doubt, Google it.
    the AC3 tells me 2:11:38 as the picture shown above but when i convert AC3 to MP3 and the mp3 file tells me 2:14:00 what's wrong ?
  1. NTSC -> PAL same movie length?
    By busta3396 in forum Mac
    Last Post: 6th Mar 2010, 06:30
  2. movie length into a avchd dvd9
    By supersam in forum Authoring (Blu-ray)
    Last Post: 14th Oct 2009, 00:42
  3. TMPGEnc Issues with length of movie?
    By doctorgonzo in forum Video Conversion
    Last Post: 11th Apr 2009, 10:30
  4. wrong movie length, audio delay
    By KlintIstwood in forum Blu-ray Ripping
    Last Post: 23rd Mar 2009, 14:10
  5. why a dvd movie's length is longer than 120 min
    By hzgg2 in forum Video Conversion
    Last Post: 5th Sep 2008, 18:20
