VideoHelp.com Forum
Results 1 to 10 of 10
  1. Hi,
    I want to resize a vcd resolution to a dvd resolution (I know I wont expect a very great quality).
    But I dont know which resize algorithm is the best:
    Bilinear,
    Bicubic,
    Lanczos
    The VCD is from a Digital TV source, so there are no noise (except a few macroblocks in scenes where there is more action).
    What resize algorithm is the best ???
    Thanks.
    I would use virtualdub, and first apply the MSU deblock filter, then resize using Lanczos. The deblock filter can be hit and miss at times, but it seems to work very well with VCD source.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  3. The VCD resolutions are also offical DVD resolutions, 352X288 or 320X240 depending on where you are.
    Do some comparisons and see if the DVD player resizing doesn't look better/sharper than converting.
    I decided to just leave my VCDs' video as is and only reencode the sound (44.1 Khz to 48 Khz) and authored them as such since reencoding:
    Took time
    Made the picture too soft
    Made the file unnaturally larger
  4. Member mats.hogberg's Avatar
    Since resizing requires reencoding, I'd strongly advise against it, if your aim is to author a VCD mpeg as DVD. There's only quality loss up that road.
    /Mats
  5. I know it's better, but I'd like to put all my videos in only 1 VTS so they must have the same resolution.
  6. Compatible Video CDs ONLY have have ONE resoltion as stated above so I don't understand why this is an issue. Why is 1 TS important?!
  7. Member dphirschler's Avatar
    I like bilinear resizing, but to resize VCD (352x240) you should just use pixel resize. No reason no to since it will be just doubling the size (704x480). You may want to add a border of 8 on the left and right (after resizing to 704) to get it to 720x480.
    Darryl
  8. Maybe it's not just VCD material?
    Possibly... but with playlists and other features other freeware DVD authoring offers you can get around that too without reencoding.
  9. Guns1inger nailed it. Just doing pixel resize still leaves you with the crappy looking 1150 kbit bandlimited aliasing blocks you get from VCD encoding, except 4 times as large, which looks really *really* bad. Lanczos is a modified bicubic and will produce the smoothering scale-up interpolation. But you must run MSU deblock, and you might want to try some other smoothing filters in addition inside the filter chain when you run VirtualDubMod.
    A whole lotta folks are taking mpeg-1 TV show downloads and just turning 'em into DVDs with straight mpeg-1 to mpeg-2 conversion via pixel resizing, and it looks craptacular beyond description. Unwatchable.
  1. New Adobe Photoshop image deblurring algorithm
    By poisondeathray in forum Latest Video News
    Last Post: 13th Oct 2011, 23:12
  2. Algorithm convert DAT to AVI
    By Nemo_wf in forum Video Conversion
    Last Post: 5th May 2010, 03:18
  3. Best encryption algorithm?
    By alegator in forum Computer
    Last Post: 10th May 2009, 23:37
  4. Understanding RGB filter algorithm
    By brianwarming in forum Programming
    Last Post: 6th Feb 2009, 21:16
  5. Replies: 3
    Last Post: 4th Jan 2008, 22:19
