Does anyone know of a issue while using progressive scan. Int. during playback there are horizontal white moving lines. I have seen one other thread on this. Have other people seen this, heard of a fix??
Any help would be appreaciated.
Thread: Philips DVP 642
I don't know if this refers to you, but progressive scan will only work with a TV that is equipped for progressive scan. If the TV is not so equipped to handle progressive scan, then disable it on the DVP642.
I have my DVP642 hooked up via component video to a Dell 2300 projector... It works great 99% of the time.. Just every once and a while I get the white horizontal moving lines...
Yes, it happens to me occasionally with Progressive Scan on, I don't know of a solution.
My A/V hardware: Sony 30" KV-30HS420, Philips DVP642/37, Logitech Z-5500 Digital 5.1, Comcast/Motorola DCT6200, PS2 SCPH-30001 (and it still works!)
I called philips they say they don't know of this particular bug.. but that there is a firmware release in the works... I hope it will be fixed in that...
Lines that are MOVING are almost always a grounding problem. Make sure all components are properly grounded; it's worth a check. In one strange instance, I had a player with a 3 prong plug that was making moving white lines, and the problem disappeared when I put it into a "ground buster" plug and REMOVED the ground. So you never can tell, but I'm betting that something which should be grounded isn't, or something that shouldn't be grounded is.
Philips DVP-642 16:9 Display
By wulf109 in forum DVD & Blu-ray WritersReplies: 4Last Post: 27th Jan 2010, 12:39 -
Philips dvp 642 help?
By imemine in forum DVD & Blu-ray PlayersReplies: 7Last Post: 3rd Feb 2009, 02:22 -
Philips DVP 5140 or DVP 642/37, which is better?
By Amuse in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Feb 2008, 16:26 -
Philips DVP 642 (37A) dvd player -does it play PAL
By Katiemay in forum DVD & Blu-ray PlayersReplies: 8Last Post: 11th Jun 2007, 23:16 -
Philips DVP-642 and x.264 HD encoding
By dfishman923 in forum Newbie / General discussionsReplies: 2Last Post: 13th May 2007, 14:36
