As header, how can i keep every thing intact but change the pcm to ac3 ??
tools i have is tmpeg dvd auther with ac3 plug in (doing movie with ac3 only is easy enough, but i want dts surround also)
ifo edit
vob edit
dvd rebuilder
shrink
have i got the correct tools ?
is there a step by step guide out there ??
I've done a search of the forums, but nothing obvious turned up,
thanks for any input guys, this is the 1st time i've needed to do this.
Results 1 to 10 of 10
Hi-
I explained to a fellow how to do this a few days ago. He wanted to replace German with French, and you want to replace PCM with AC3. Same idea:
http://www.videohelp.com/forum/viewt...841&highlight=
It's not the recent release of the Cream reunion concert, is it? Damn stupid idea if you ask me, PCM and DTS on the same DVD. And it's full bitrate DTS. Over 3000 bits of the available 10000 wasted on the audio.
And you don't buy that DVD for the audio track?
IOWs it makes sense to me.
I seem to recal a Fleetwood Mac flippy that had DTS or AC3 on one side and LPCM audio on the other side.
its the queen + paul rodgers dvd, return of the champions....
this link looks far too hard, so, i've re authered main movie in tmpeg dvd auther, so now i need to rip the dts audio from original, and add to my ac3/movie only dvd, how ??
c-mon guys, some buff here should be able to put me on the right path .......
Guns1inger:-You're right, TDA won't take DTS. I was suggesting a simple way of copying movie file to HD as an mpeg with TDA and then demuxing to rip out audio (we have the DTS already via VDubMod-stream list). I should have said in my post "Cannot reauthor back with TDA after this because of DTS. An alternative authoring app is needed."
DVDLab Pro, DVDAuthor and a few others will.
this thread is over 4 yrs old. if you have a query then pls start a new one because your reply is going to everyone else
i am sure that in over 4yrs your question would have been answered.
Difference Between DTS 5.1 & Dolby Digital AC3 5.1
By dorababu in forum AudioReplies: 6Last Post: 30th Nov 2010, 01:41 -
PS3 & DTS
By Bazza-61 in forum AudioReplies: 2Last Post: 26th Sep 2009, 03:08 -
DTS wont play through amp
By Bazza-61 in forum AudioReplies: 11Last Post: 24th Sep 2009, 09:54 -
DTS & AC3 not muxing with WMV properly
By soadtrails in forum AudioReplies: 7Last Post: 31st May 2009, 17:40 -
How to convert .ac3->ac3wav & .dts->dtswav?
By ontherocks in forum AudioReplies: 10Last Post: 14th Dec 2008, 16:56
