Hello all,
I've got an SVCD that I'd like to play with external subs.
I can load up the subtitle file in Media Player Classic whilst the SVCD is playing but the .srt is out of sync (was created for another release I believe).
Anyway, I can't find a setting to allow me to resync the titles by altering subtitle delay (as you can do in FFDSHOW and VobSub direct).
I usually use Zoom with FFDSHOW to play .avi's but Zoom doesn't seem to handle SVCD's well. I've enabled MPEG2 and MPEG1 in FFDSHOW but when I try to open the SVCD in Zoom it takes about 1 minute to open and then stutters, hence the reason I'm trying to use MPC.
If anybody can tell me how to change the MPC subtitle sync settings or let me know how to make MPC use the FFDSHOW filters (thus allowing me alter the timing of the subs from within FFDSHOW) then I'd be very grateful.
Cheers.
JA
Results 1 to 1 of 1
Media Player Classic Lip Sync
By rckowal in forum Software PlayingReplies: 2Last Post: 9th Jan 2011, 12:31 -
Media Player Classic - subtitle
By pchan in forum SubtitleReplies: 13Last Post: 16th Nov 2010, 07:37 -
MPV and MPA out of sync with Media Player Classic
By Talayero in forum Newbie / General discussionsReplies: 2Last Post: 13th Mar 2009, 08:34 -
Media Player Classic (Subtitle Problem) !
By Bahez in forum Software PlayingReplies: 1Last Post: 2nd Jan 2009, 06:19 -
Changing Media player Classic background
By punisa in forum Software PlayingReplies: 9Last Post: 27th Sep 2008, 08:29
