VideoHelp.com Forum
    Hi
    I am using Ultra DVD creator from Aone to backup some DVD's (Anyone with experience with this sw?). One of the DVD is ripped by first doing a simple copy from the dvd disc to a folder on the PC an then I have used DvdShrink to re-author this folder. But, when I am trying to burn a DVD+R wit Ultra DVD creator it fails in making an image and report error "Cant parse audio option 0ch". I have no troubles in playing the content in the folder. I have also tried to burn the "raw" copy from the DVD using Ultra DVD (i.e. DVDshrink has not been sniffing on the file first), but the same problems occoures.
    Any ideas in how to fix this trouble. Should I try to demux the vob file?
    Thanks for your help
    (No, i cant do a rip direct from the DVD at the moment since do not have it here with me, maybe later if you think that would solve the problem.)
    Regards
    Zainka
  2. Member MackemX's Avatar
    how are you using DVDShrink? Are you removing audio and is it set to remapping the audio?
    check out SmileyPic if you love using smileys :) (LINKSKI)
  1. parse ts pcm stream
    By niror in forum Audio
    Last Post: 2nd Oct 2011, 01:36
  2. What does this .d2v parse tell me?
    By fatcharlie in forum Newbie / General discussions
    Last Post: 10th Mar 2011, 17:13
  3. When does SUPER parse video files?
    By yoda313 in forum Video Conversion
    Last Post: 28th Mar 2010, 18:16
  4. MPEG 1 - Can't parse stream
    By Fr3d in forum Programming
    Last Post: 18th Oct 2009, 19:20
  5. QT can't parse error converting mpeg-1 to DV
    By jglass in forum ffmpegX general discussion
    Last Post: 22nd Jun 2008, 10:57
