Hello,
I spent some time reading through some of the reviews of various players on the site and I'm very confused.
My friend's father purchased a unit for himself. I'm not sure what it is. I've never seen it. However he converted a concert 2 VHS tapes not available on DVD for us and I've added menus with TMPGEnc DVD to one of them. The other sorta had like this black bar on the right side frame. It runs from top to bottom. I'm not sure if it's the tape itself or how he converted it.
He did two of them where the quality of the video was as good as can be expect for a video. However, I'm not happy with how they came out.
So instead of harassing him about I think I'm just going to buy one of my own. I want to know what I basically need to look for. I'm not sure how much I want to spend as I'm not sure what I'm looking for. If the best is $100 I'll buy it if the best is $900 I'll buy it. I don't exactly want to spend $900 but as my aunt likes to say you can't afford to buy cheaply.
Any help would be great!
Why not buy a capture card for the computer so you can edit it after you record it? Hauppauge wintv pvr 250 is great for mpeg only captures.
BUT if you want to do a lot of editing try an ati all in wonder capture card. You can get used ones for under $100 on ebay I'm sure.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
heh.
Capture card? No. I think stand alone, rip, and edit is way easier for me.
My motto is never open the computer.
Although they probably make them, I haven't seen a really good combination unit.
You're better off with a really good VCR, look here: http://digitalfaq.com/dvdguides/capture/playback.htm
And a seperate DVD recorder: http://digitalfaq.com/dvdguides/buye...drecorders.htm
Be aware that some tapes are copy protected with macrovision which requires some means to bypass it."Art is making something out of nothing and selling it." - Frank Zappa
Thanks for the links Zippy.
Most of the vids I'm converting at bootlegs to be honest. The quality is as good as can be but I'd like to jazz up the picture a bit.
I have a great Sony VCR that is hardly used so perhaps just the DVD recorder is best. I do hate combo units as if one breaks the other is just sorta stuck with it.
I assume all you have to do is is connect the VCR and DVD player via the A/V cords and just follow the instructions on how to record in the DVD player manual?
Also, can a stand-alone DVD-recorder record live TV?
Yes, you just select the input that you wish to record from...s-video, DV (if present), video 1, video 2 or TV. It's much like a VCR and don't try to get more than 2 hours on a disk for best quality.Originally Posted by generaljoy"Art is making something out of nothing and selling it." - Frank Zappa
Adivce on purchasing a stand alone media player online
By Cornholio77 in forum Newbie / General discussionsReplies: 17Last Post: 26th May 2011, 08:04 -
How you can use a stand alone DVD recorder and your Canopus 110
By fuzzblaster in forum CapturingReplies: 22Last Post: 3rd Oct 2010, 12:06 -
Need advice on purchasing a new DVD recorder.
By MOTUfan in forum DVD & Blu-ray RecordersReplies: 25Last Post: 21st Apr 2009, 11:40 -
Typical lifespan for a stand-alone DVD recorder.
By usually_quiet in forum DVD & Blu-ray RecordersReplies: 114Last Post: 27th Nov 2008, 21:21 -
Purchasing new dvd recorder vcr combo - wanting to copy pay per view
By rbusenbark in forum DVD & Blu-ray PlayersReplies: 3Last Post: 18th Jun 2008, 15:27
