Avi H264 can open only with ffdshow?
TMPGEnc 3.0 XPress cannot open Avi H264/X264 even if ffdshow install.
I have only play option with Windows Media Player
Do I have alternative codec to open H264?
Results 1 to 9 of 9
try some older or newer versions of ffdshow
http://www.videohelp.com/forum/viewt...ighlight=h264+tmpgenc
Or use avisynth, make a video.avs file with
DirectShowSource("C:\video.avi")
replace c:\video.avi to the location of your video.
Try then open the video.avs in tmpgenc (be sure to increase the direct show prirority in tmpgenc).
You need to make sure that AVC/h.264 is enabled in ffdshow's VfW decoder config or it simply won't decode it via VfW.
Ok
Thanks to all.
Can't QUICK TIME 7.0 open these files?
Works here!
No.Originally Posted by dcsos
Only ffdshow can open.
QT 7 does support h.264, but only main profile, also the avi container would probably be an issue. MP AVC in an mp4 or mov container should be fine though. I guess an avi might work if it used avc1 for the fourCC.
http://www.amug.org/amug-web/html/am...articles/h264/Playing H.264 or AVI
If you convert a video to AVI you should know that QuickTime 7 is not able to play any of the AVI files I have created. However, VLC media player for Mac OS X plays AVI formatted files on the Macintosh and just about every other format you send its way. No Macintosh should be without VLC. In fact, VLC played H.264 (AVC) files before QuickTime was able to. So if you want to create AVI videos get VLC for playback. For those that have the computer horsepower and the patience to create H.264 format videos you will find that they play with QuickTime 7, VLC and iTunes 4.8.
so those avis I have arent h264 but something else!
Doesn't mean that they aren't h.264.
People have been refering to XviD/DivX avi's as MPEG-4 for ages so if an XviD avi is MPEG-4 then by the same token an x264 avi is h.264.
how to use ffdshow to encode captured video into h264 in directhow
By vrparekh@gmail.com in forum Video StreamingReplies: 0Last Post: 23rd Apr 2012, 11:08 -
How / where do i disable coreavc and enable ffdshow to handle H264
By timbre in forum Software PlayingReplies: 3Last Post: 11th Feb 2010, 07:29 -
Open ffdshow config screen without opening a movie
By F u r u y á in forum Newbie / General discussionsReplies: 5Last Post: 11th Jan 2009, 03:36 -
Possible to get VirtualDub to open wmv/flv files without ffdshow?
By tigerb in forum Newbie / General discussionsReplies: 5Last Post: 20th Nov 2008, 20:09 -
Rendering inconsistencies (ffdshow/h264)
By pfxz in forum Newbie / General discussionsReplies: 5Last Post: 29th Jul 2008, 23:18
