VideoHelp.com Forum
Results 1 to 11 of 11
  1. I have a few episodes/clips on my computer of certain shows that are in .mpeg format. They run between 10 minutes & 30 minutes. I want to keep them on my cpu but I don't want to waste a lot of space. Can someone recommend how to get the file size lower. Right now they're at about 250 mb for about 10 minutes of video. Is there a format that can shrink that size? I don't mind losing a bit of quality on the video but nothing excessive. I know .wmv is an option but is there anything else?
  2. VH Veteran jimmalenko's Avatar
    Running Time and bitrate are the only two variables that affect filesize, so you can always just lower the bitrate. Of course this generally means a lesser quality, which means that you may have to lower the frame size as well. Or you can use a more compressible codec, such as WMV, DivX, XviD ..... to name but a few.
    Without knowledge of the frame size and bitrate of the source, it's a bit hard to give you any solid info.
    If in doubt, Google it.
  3. How can I check what the bitrate is? Gspot Codec Info is saying n/a so I'm not sure what's wrong. How would I go about shrinking the bitrate? What would make a smaller video size (divx or xvid?). Thanks for all the help!
  4. VH Veteran jimmalenko's Avatar
    Try the latest GSpot Beta (2.52). It reads MPEG files properly.
  5. ok cool...here are the specs
    sys bitrate: 2210 kb/s VBR
    MPEG-1 System Stream
    Length - 7:21
    Frms - ~11026 kbps - ~2082
    Pics & Frames Per Sec - 25.000
    Seems like the bitrate is really high. Any ideas?
  6. VH Veteran jimmalenko's Avatar
    Frame size ?
  7. 448*336
    I'd like to keep the frame size the same if possible?
  8. also
    bitrate = 1204569 bps
  9. Are there any good programs to convert to .wmv? I tried boilsoft asf converter but it always shrinks the frame size regardless of what i specify.
  10. VH Veteran jimmalenko's Avatar
    Your video bitrate is 2082kbps, and looks like 128kbps MP3 audio.
    I'd either use Windows Movie Maker and the High Quality video (small) template, or use AutoGK and convert to XviD.
  11. ok i'll try them out...thanks for the help!
  1. best format and size to convert a vcd dat file to for archiving?
    By perfection in forum Newbie / General discussions
    Last Post: 1st Apr 2012, 03:59
  2. Encode MPEG-4 to DVD Format Without Doubling File Size
    By JustAnotherUsername in forum Authoring (DVD)
    Last Post: 6th Feb 2012, 22:10
  3. convert compressed avi files to mpeg without increase in file size?
    By jasoothai in forum Authoring (VCD/SVCD)
    Last Post: 2nd Nov 2011, 05:29
  4. Shrinking a video file size
    By gilmer in forum Newbie / General discussions
    Last Post: 7th Nov 2009, 23:14
  5. Help Regarding convert the large size videos of several format
    By darkstonecold in forum Video Conversion
    Last Post: 3rd Sep 2009, 14:27
