Please give me a guide to make the "STOP" button on the remote control, so press the "STOP" button it will return to main menu of the dvd.
I'm using dvd-lab Pro. I tried to search from this forum and the site under DLP, I couldn't find it.
Pardon my ignorance, but isn't that what the Menu or Title buttons on your remote are for ?
If in doubt, Google it.
Actually, I want to make stop button to return last menu (sub-menu) or after a splash screen and then back to main menu
you can't program stop commands.
dvd specs allows user to program only for these remote interruptions:
root menu
title menu
audio menu
subtitle menu
chapter menu
angle menu
every item of dvd programming occurs during a pgc vm pre or post commands/button commands/cell commands.
stop button is a feature of the dvd player itself, hence you cannot program its function.Some people are only alive because it may be illegal to kill them
I can do this in Adobe Encore
i haven't had experience with adobe encore. I'm a scenarist user, and when you press stop, the dvd player itself should overide any user programmed controls, and if the dvd has jacket picture information, it should display a picture. Now since those jacket pictures are just mpeg pictures, they don't have any navigational timeouts, you press play again usually to resume your disc. If no jacket pictures defined, then stop basically puts you to the dvd screen saver, waiting for you to press play again to resume. I know this is from about 14 dvd players i have tested on, from high end, to low end.
You can use PUOs to override and block the use of stop, but certainly with DVD Lab Pro you can't assign it another function.
How to remove annoying "Press Esc to ..." message in Flash Video
By roma_turok in forum User guidesReplies: 238Last Post: 10th May 2012, 09:59 -
"DVD Lab Pro"/DVD Authoring for Mac?
By Paker in forum MacReplies: 4Last Post: 8th Aug 2011, 01:50 -
DVD Lab Pro Error: "Read data size is over the buffer limit"
By Motinha in forum Newbie / General discussionsReplies: 0Last Post: 29th Oct 2010, 02:49 -
DVD-lab PRO v1.6 - "Map" only gives the color black
By Paker in forum Authoring (DVD)Replies: 1Last Post: 3rd Sep 2009, 13:30 -
DVD Lab Pro - Three elemenetary "hot to ....." questions
By perfection in forum Authoring (DVD)Replies: 2Last Post: 1st Sep 2007, 06:45
