If I burn a DVD with 2+ video files on them, without having a menu, will it be possible to skip to the next video file on a standalone DVD player?
Results 1 to 11 of 11
Yes.
Depends on how you author it, which application you use, etc. An easy way (using DVDLab Pro) is to use a playlist. Add whichever clips you want to play, in order, and you can link them to one another in any order, have them skip to different menus or whatever you want.
flonk!
There is a scan forward button on every DVD player that I have seen.
http://www.kiva.org/about
if i author with TDA each video file is automatically a chapter on the finished dvd.
Use the <Next> button on the Remote Control to skip the file or the <Scan Forward> button as it's been suggested here
k, because I burned a DVD with 2 movies on it, using TMPGenc DVD Author, and when I play it back on PowerDVD, it just recognizes it as one big movie file. So I can fast forward to the next movie, but not actually skip to it.
You need to add chapter points.
apparently you authored it incorrectly for what you want it to do. should have authored them as separate TITLES/TRACKS (add track), do not include any chapter points on the first title (at least) so when you hit the next/forward button on your remote it will go to the next title.because I burned a DVD with 2 movies on it, using TMPGenc DVD Author,
Oh, so I'm supposed to add a new track instead of adding another file under the same track. Thanks.
Darn...wasted a DVD.
NeroVision Xtra: Poor menu text rendering; no chapter skip
By Grunberg in forum Authoring (DVD)Replies: 0Last Post: 23rd Apr 2011, 18:02 -
how to skip main menu
By arumugam49 in forum Authoring (DVD)Replies: 3Last Post: 24th Oct 2010, 08:08 -
Fixing DVD so it does not skip menu on start-up
By danielmak in forum MacReplies: 6Last Post: 30th Dec 2009, 02:45 -
DVD RIP, Audio and Video Skip/Lag
By Blue_3 in forum DVD RippingReplies: 4Last Post: 8th Apr 2008, 07:34 -
DVDLab Pro VMG and Menu Button and Chapter Skip on Remote
By raouliii in forum Authoring (DVD)Replies: 2Last Post: 20th Dec 2007, 13:08
