I have some clips that I am trying to blend together using tmpgenc dvd author, but the program is telling me the the 6-channel clips and 2-channel clips cannot be combined. That is understandable. How (without re-ripping all of the clips again) can I upconvert the 2-channel tracks or down convert the 6-channel tracks to make the disc work properly. Honestly, the audio quality isn't that important to me for this particular disc, but upconverting would be faster because there are fewer of the 2-channel tracks.
Thanks - Lockheede
Find the 6 channel audio, demux it to 6 mono wav files, use your audio editing software to mix them down to a stereo output
or
Split your stereo into 2 mono wav files, duplicate until you have six files, then encode to 5.1
The first will give you better quality.
ffmpeggui or besweet will be your freeware tools for this.
Thanks for the reply. I guess that takes me to the next step...how do I extract the audio from the VOB/IFO files and re-encode back to that format?
Premiere: Duplicate left audio channel to the right channel?
By ash_melb in forum EditingReplies: 6Last Post: 13th Apr 2012, 14:55 -
DVD with mono audio channel...can i convert to two channel
By maass in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2009, 21:46 -
Multi-Channel sound on 4350 not working 100%, (ONLY 2-channel)
By THX-UltraII in forum AudioReplies: 1Last Post: 20th Feb 2009, 04:35 -
Convert single channel to double channel audio ...
By tariq_niazi in forum AudioReplies: 3Last Post: 15th Nov 2007, 16:47 -
Converting a Mono Left Channel to Double Mono Left/ Right Channel on a DVD
By socool135 in forum AudioReplies: 5Last Post: 16th Sep 2007, 00:45
Statistics
Newest guides
Latest tool updates
New media comments
