  1. Cinema Craft Encoder outputs video files in .MPV format.
    Does anybody know what program will run an .MPV video file?
    Because my computer doesn't recognize that kind of file.
    Thanks!!!!!
    Chris
  2. MPV is an elemantary stream. Try to Mux the Audio to the video if no Audio Try to rename to MPG.
  3. I also think Media Player Classic will play it.
  4. Member Bodyslide's Avatar
    Feb 2002
    A Different Timeline
    VLC might also play it
    Dec 2004
    Australia
    Pretty much anything should. As said it is just an elementary mpeg stream. You will need an MPEG2 decoder if you were encoding MPEG2 though. MPC and VLC both have built in MPEG2 decoders.
