VideoHelp.com Forum
Results 1 to 9 of 9
    Where do the files .idx and .sub (used for subtitles) in movies come from?
    Are they found on DVDs, or what?
    Thanks.
    Sort of. They are created from the DVD's IFO and subtitle streams in the VOB's. So whilst they aren't directly part of a DVD, they are created directly from it.
    VobSub ripping was replaced with VSRip some years ago.
  4. Member mats.hogberg's Avatar
    Originally Posted by mats.hogberg
    ...with VobSub.
    ...or VSRip, then!
    /Mats
    Is there a way of converting sub/idx back to srt, without having to enter characters that it doesnt recognize? (like in vobsub).
  6. Member mats.hogberg's Avatar
    It's not back to str. Most likely, a VobSub subtitle has never been a .srt subtitle. "Only" way to go VobSub to srt is using SubRip. Even if there are (are there?) other VobSub to srt rippers, OCR is involved, and OCR has to be trained to recognize characters. Once you've told SubRip what every character looks like, which I don't find that taxing, it's a remarakably swift process IMO.
    /Mats
    Hmm...so why use .idx and .sub in the first place, if you can't use them to burn a DVD?
    Because sometimes there's subtitles in different languages, and you can't type those characters for it to recognize.
  8. Member mats.hogberg's Avatar
    Why take the DVD apart at all, if all you want to do is recreate it? Mostly, it's a convenient way for producing AVIs with selectable external subs (from a DVD).
    sub + idx are the subs just as they are on the DVD. Basically a series of still
    images, that gets overlayed the movie at times specified in the idx file. A very simple procedure, as far as image processing goes.
    You can use sub2sup to convert it to .sup format, that ReJig and IfoEdit can use when authoring a DVD.
    /Mats
  1. Editing idx/sub files
    By mrcoolekin in forum Subtitle
    Last Post: 15th Oct 2009, 07:44
  2. Join sub/idx files?
    By waefwaeefwaefw in forum Subtitle
    Last Post: 3rd Oct 2008, 03:14
  3. question about extracting idx/sub files from DVD
    By jimdagys in forum Subtitle
    Last Post: 24th May 2008, 09:49
  4. Replies: 5
    Last Post: 29th Mar 2008, 08:58
  5. VSRip..where are the idx/sub files saved to?
    By Soixante in forum Subtitle
    Last Post: 16th Jul 2007, 13:50
