I'm fairly new to this.I've used the video blaster movie maker, results sucked. what will give me the best looking vcds. I have a pioneer dvd333 and are not sure if it will play svcd. I am looking to buy a new capture card dvc2 or something like it.I am willing to capture and use something like TMPGEnc to convert to vcd format if this will help quality. I am hoping for results near vhs quality. any good advice please let me know. thanks taz.,
hey tazzila. I just started useing Dazzle DVC II pci and am getting good results. Capture in MPEG 1 with a video bitrate of 4000. Encode to VCD useing TMPGEnc with a 2000 cbr. Of coarse the quality of the finished product depends on the quality of the tape that is used for import. Check the DVD player compatibility list to see what formats your Pioneer will play. Good luck
I am getting frustrated, i got a dvc 50 and when i capture, the capture is too big i can't even capture over a half hour, my goal is at least a 2 hour movie... Can someone give me pointers on curing this problem.. Thanks a bunch
Darkstar Photonis
In movie star you can set the max size of the file, but i am affraid that I don't know anything about the DVC 50. Are you running up against the 4g limit that wndows imposes?
do u get alot of dropped frames
use virtual dub and do on the fly DIVX compression
Capture Analog 8mm Video 8 Tapes to DV - What equip will produce best Qual
By koop in forum CapturingReplies: 7Last Post: 4th Apr 2012, 23:36 -
How do I capture my VHS tapes to DVD
By tfoster in forum Newbie / General discussionsReplies: 4Last Post: 26th Jan 2011, 11:57 -
Can I capture Hi 8 analog tapes directly to iMac?
By tadd5181 in forum CapturingReplies: 2Last Post: 21st Apr 2010, 19:48 -
Problems capturing analog video from VHS tapes
By jdwmba in forum CapturingReplies: 8Last Post: 15th Mar 2008, 17:52 -
New Capture VCR for old VHS/SVHS tapes
By mark23 in forum CapturingReplies: 3Last Post: 22nd Feb 2008, 09:44
